Hardcore CD burner help
Old Dec 31, 2005 | 06:37 PM
jake00's Avatar
jake00
Time to bring up an old thread from the dead.
I'm getting the SAME DAMN PROBLEM after reinstalling windows, I actually installed windows on a brand new hard drive, Maybe my whole computer is jinxed
Old Dec 31, 2005 | 06:54 PM
DaveMac2Vans's Avatar
DaveMac2Vans
Sounds like a bad drive. Plug in another burned and see if that one runs.
Old Dec 31, 2005 | 06:58 PM
jake00's Avatar
jake00
tried that tooo and cable,
Old Dec 31, 2005 | 11:11 PM
Mil1ion's Avatar
Mil1ion
When was the last time you cleaned up the files on your puter ?
I had the same problem so I did a clean-up of all the junk files on Drive C.
Now XP recognizes the CDWriter & DVD writer.
Old Dec 31, 2005 | 11:21 PM
jake00's Avatar
jake00
last week i got a brand new hdd and did a fresh install of xp sp2
Old Dec 31, 2005 | 11:22 PM
Mil1ion's Avatar
Mil1ion
What does the device manager say about the drive in question ?
Old Jan 1, 2006 | 07:22 AM
mistakenID's Avatar
mistakenID
Does the bios recognize the drive? Maybe try setting the bios to defaults, save and exit. That should make the bios update components.
If the bios does not recognize the drive, it's either a bad drive or a bad IDE. Since you said you already tried a different cable and drive, it points to bad IDE. At that point I suppose you could try to update the bios.
Have you put the drive on the other IDE?
Old Jan 1, 2006 | 11:30 AM
jake00's Avatar
jake00
nothing outa the orinary
I'ver put the drive on the other ide and on a controller card,
the bois recognises it and windows recognises it, I have a few other drives laying around here, I'm gonna try those
Old Jan 1, 2006 | 09:35 PM
furball69's Avatar
furball69
For some reason my computer doesn't like it when a burner is by itself on a cable, it has to be on a cable with another drive. Two different burners and same story. make sure the jumper is set in the right position.
Old Jan 1, 2006 | 09:36 PM
jake00's Avatar
jake00
im thinking my mobo is boned
tewferford
May 16, 2007 02:45 PM
seventyseven250
Nov 24, 2006 10:33 PM
88grandmarquis
Jun 6, 2005 07:33 AM
88grandmarquis
Oct 13, 2003 12:45 AM
karljay
Mar 16, 2003 02:20 PM
