Computer question, using CD based application without CD
Old Nov 23, 2006 | 08:08 PM
seventyseven250's Avatar
seventyseven250
I've got a CD-based program that I would like to be able to use stright from the hard drive. Does anyone know how to do this? I suspect this particular application is built this way to prevent a person making copies of it. I'm not trying to make illegal copies, I just get tired of waiting for the data to transfer from CD.
Anyone?
Old Nov 24, 2006 | 03:11 AM
VikingBabe's Avatar
VikingBabe
I am more familar with games that require a cd to run because of some security key to prevent piracy.
With some, you can change the cd path by finding looking under "Engine.engine" and change the path to "no path" or add an ' before cd path. This way you do not need to use the cd. The computer thinks it's already running. It depends on the game's "run" file whether or not something like this can be done.
But what you are asking about is called a "no-cd crack". I know gamers who use this for the same reasons you mentioned. They legitimately have the game but their disk has become so scratched to use or is broken or want to burn to a disk and keep the original stored away.
What might be taking so long is your computer reading the security code to make sure you are the proper person before transferring the data. Piracy is a huge business and software companies lose millions (if not billions) of dollars. They try to install all kinds of security to try to prevent this. But it's the legitimate users that have to suffer for what the pirates do.
Old Nov 24, 2006 | 03:14 AM
furball69's Avatar
furball69
Daemon Tools might work. You'll need to make an image of the disc and copy that to the HD, then once you mount the image, run the install from it. All depends on the possible protection and whether it gets copied or not.
YOu might also try to increase the amount of time your drive waits to spin down.
Old Nov 24, 2006 | 04:25 PM
rebocardo's Avatar
rebocardo
Sign in as ADMIN. Create a partition/drive, create a share for it, copy the CD to it, write protect, read only. Sign on as a normal user and install. That is how I do it for WinNT/2000.
Most software uses a simple test to see if it can write to the disk, if it can not it assumes it is a CD or a CD on a network share.
Old Nov 24, 2006 | 10:33 PM
furball69's Avatar
furball69
There's no copy protection on a windows CD, no need to make a partition for it either. Look up Securom, CD-Cops, CrypKey, HexaLock, SafeDisc V1 - V4, SoftLock, DiscGuard, LaserLock...
Many more exist.
Seventyseven,
Another possible thing to look into is how the program was installed. Sometimes the "Typical" install leaves files on the CD, where a "Full" install will copy all files to the HD for faster access times and it will just check at the start of the program for the original CD.
and if you still haven't found a solution check out "cd media world dot com" , one word.
Nitramjr
13
Feb 28, 2007 11:31 AM
Brian_B
Sep 12, 2006 06:05 AM
88grandmarquis
Jun 6, 2005 07:33 AM
sandrat
Jul 16, 2004 04:39 PM
Mike W
Sep 16, 2003 06:49 PM
