bronco lacks power
Old Aug 28, 2005 | 01:32 PM
gary90bronco's Avatar
gary90bronco
Talking bronco lacks power
recently my bronco suddenly had a power loss while towing since then i have installed new cap roter wires & plugs fuel pressure stays between 32 to 40 psi i did replace one injector with a new one when i found it was doa when i run a code scan the only thing that comes up is a code about the egr position switch that is new timing is set to factory specs on some mornings when is start my truck to go to work it runs fine untilthe engine is up to temp but this doest allways happen
Old Aug 28, 2005 | 09:09 PM
FordPerf300's Avatar
FordPerf300
Check and replace if necessary the coil and TFI module. Are you sure it's engine related or the transmission is slipping?
Old Aug 29, 2005 | 01:03 PM
Kemicalburns's Avatar
Kemicalburns
what plugs and wires are you using? check them at night for arcing this will drain power for sure. you didnt say what motor you have but bumping the timing up to 12*btdc with the spout connector removed will wake it up for sure. how many miles on motor you might think about a compression test. also a clogged cat can cause significant power loss. is your exhaust stock still?
coleaclark
1978 - 1996 Big Bronco
Mar 16, 2015 10:38 AM
robjs111
15
Feb 15, 2014 01:48 PM
Speedshifter
Jun 1, 2010 08:11 PM
3headakid
Apr 6, 2010 08:46 PM
red351
Aug 24, 2006 07:48 AM
