I have a problem with my bronco! It doesn't Idle up when I start it or when I turn the a/c on. there no codes. I put in a new idle circuit, a new pvc and a new tps. Every ounce in a while she revs to 2000 rpms I shut it off and restart it it runs fine, if I unplug the IAC it revs to 2000 rpms I plug it back in and the idle goes back down I disconnected the battery for ten minutes and it still does it what gives?? I am confused Please help
No codes? I find that impossible to believe especially if you have disconnected the IAC. That alone will generate a code for an open circuit to the IAC. And even if there are no faults the code 11 or 111 will be returned which indicates the system passed the self test.
Exactly what did you replace? Not sure what you mean by "idle circuit".
I'm going to also say that its probably the IAC. I have not had much luck cleaning them. Sometimes it helps and sometimes it doesn't. Usually I just replace them.
As I mentioned earlier the IAC being disconnected should generate a fault code and furthermore with the engine at full op. temp. disconnecting the IAC should cause the truck to fall on its face and die at idle. If it doesn't, you have a vacuum leak or worse, someone has messed with the throttle plate stop screw in the throttle body. Either is something that must be rectified before your idle problems will go away. Cleaning the IAC won't do anything if the idle takes off with it disconnected.
Disconnecting the IAC with the engine running or starting with it disconnected WILL generate code 81 or 543 depending upon the age/model ECM in the vehicle. You can have idle issues related to the IAC without getting codes but disconnecting the IAC WILL generated "IAC circuit failure" codes.
No big deal really... you are correct in that you can have idle issues caused by a dirty IAC and never get a code from it. But the OP stated he had disconnected it and still gotten no codes which is impossible unless it was reconnected BEFORE he started the truck again.
There is no idle control sensor... the IAC is the actual valve and solenoid air flow control for the engine at idle. The engine functions at idle are controlled by a series of thermostatic and pressure sensors that monitor the "ignition trilogy" (air, fuel, spark/heat). The MAP, ECT, O2, and TP all contribute to the information the PCM uses to maintain idle.
Any condition that allows the engine to idle HIGHER with the IAC disconnected is more likely a vacuum issue or an idle stop screw that has been adjusted... BTW it should NEVER be adjusted.
You've got to replace the Idle Air Valve AND Throttle Position Sensor.
You've got to replace BOTH of them.
Make sure you disconnect the battery before you put them in.
Then reconnect the battery AFTER they are both in.
They work together, and they program themselves.
If there are no codes being thrown to indicate there is something wrong with the TPS, it is unlikely that replacement is necessary. TPS can develop "dead spots" like any potentiometer but with the problem being at idle, if there was a problem with the TPS you would get a fault code.
