springs
Old Aug 26, 2005 | 01:19 PM
g84t8f1's Avatar
g84t8f1
springs
Hi All. Is There Any Newer Autos Out There That Springs Will Fit My 48 Without Changing The Hangers?hate To Buy New Ones.
Thanks
Art.
Old Aug 26, 2005 | 02:12 PM
ferguson777's Avatar
ferguson777
You're asking a lot;
Correct width (I think you want 2" wide whereas I think most leaves today are about 2.5" wide today)
Correct arch and length from eye center to eye center.
Suitable load rating.
Are the bushings in the eyes the correct I.D.?
All those factors come in to play.
Whole new 48 spring packs run about $350. per side but your local spring shop might be able to do a little better.
Or you should be able to buy just the main leaves at about $65. each from folks like Sacramento Vintage Ford or others......
Maybe someone has gone this route successfully and has the answer you want though....
Good luck,
Old Aug 26, 2005 | 06:54 PM
jwcnj45's Avatar
jwcnj45
It's been a few years but my local spring shop sold me a new set for $400.
Old Aug 26, 2005 | 08:55 PM
g84t8f1's Avatar
g84t8f1
Thanks Guys.i Can Get New Ones For 299.00 A Side.may Not Even Need Them Just Wanted To Check And See.
Art
Old Aug 27, 2005 | 06:59 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Art,
I know you don't want to change the hangers, but I used a pair of rear springs from my 87 Chrysler 5th Avenue front suspension donor car in my 48 F-3 which I shortened to F-1 length. The springs are a tad longer but do not interfere with running board brackets and a couple of simple 'L' shaped brackets mounted to the side of the frame rails work fine for mounting. I also used the Chrysler rear end and shocks. I wanted to rid myself of the ancient truck spring hangers and 13 leaf springs and soften the rear suspension. This seems to have worked out very well for me. It might be worth taking a look at. I expect a very nice ride from these springs.
Vern
Old Aug 27, 2005 | 09:10 AM
g84t8f1's Avatar
g84t8f1
Thanks For The Info.got Any Pics?i Would Like The See What It Looks Like.and How You Mounted The Hangers.
Art
Old Aug 28, 2005 | 07:32 AM
GreatNorthWoods
Art
Art,
I did take some but when I took the film to be developed none of the pictures came out. I will take some more pictures sometime in the next few weeks and put them in my gallery, but don't know when I might have them.
Vern
Old Aug 28, 2005 | 07:56 PM
g84t8f1's Avatar
g84t8f1
i'll be looking for them.
THANKS
ART
Old Aug 28, 2005 | 08:01 PM
jaye's Avatar
jaye
I just bought the MLO and put new bushing and hanger on the front; on the rear I went to the salvage yard and had them cut the rivets on a pair from a small bronco I just centered and bolted them to my frame with grade 8 bolts
P.S. while you are at it CHANGE those king pins it will make a world of difference!
Old Aug 29, 2005 | 10:12 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I had the front prings on my 49 rebuilt by a local spring shop. They were in pretty bad shape and had several busted leaves. All told I think it cost me about $150 after I bought new bushing and pins too.
Bobby
Old Aug 29, 2005 | 01:34 PM
g84t8f1's Avatar
g84t8f1
Thanks For All The Info.i Might Have Them Redone If Need Be.
Art
crash1
17
Apr 21, 2012 07:25 AM
muscletruck7379
May 15, 2004 11:51 PM
johnsdiesel
All Things Towing
Jan 13, 2003 02:32 PM
winfordr
Aug 18, 2002 12:48 PM
iknowitall
All Things Towing
May 18, 2001 10:09 AM
