Sponsored by: Kumho
spring rate
Old May 14, 2004 | 11:22 PM
muscletruck7379's Avatar
muscletruck7379
spring rate
how can i measure and change spring rate on leaf springs?
Old May 15, 2004 | 11:06 AM
Ecuri's Avatar
Ecuri
Leaf springs do not have a nice formula like coils do, as I guess you have noticed.
However, the rate can be computed experimentally. You will need a dial-indicator and some incremental loads. (a forklift and sand bags would sure be handy here, or a bunch of friends with known weights to get into the truck, don't forget to add in the weight of the beers in there hands!)
You need to set up a dial indicator between the axle and the bed to measure the deflection. Put some jack stands or blocks under the front bumper so that no load can be absorbed by the front springs. Start adding weight, directly over the axle and keep it centered to prevent errors. Record deflection and weight and start graphing or charting. Do the math. (Of course, the rate per spring is 1/2 of the measured rate.) I have used this technique to compute and adjust front coils and results were extremely coincident with prediction. I am kinda curious what you find. Is the rate linear or progressive?
As far as changing the rate, the only way I know is to have a spring shop re-make leave(s) thicker or add more leaves in. (Or shorter, but I don't think you want to go there.) GL
Old May 15, 2004 | 01:30 PM
ldbranda's Avatar
ldbranda
Talking
sounds good to me.
Old May 15, 2004 | 11:51 PM
muscletruck7379
i will do so as soon as i can get a dial indicator. i have always thought one would be useful.
LittleBlue79
Mar 26, 2017 07:00 AM
Diesel_Brad
Jan 29, 2017 06:20 PM
chad77
Apr 5, 2016 11:49 AM
jrockdiddy
Mar 26, 2013 11:39 AM
DIYMechanic
Oct 19, 2011 07:39 PM
