sd obs springs
Old Apr 19, 2012 | 11:30 AM
crash1's Avatar
crash1
sd obs springs
on standard sd spring mounting on to obs in relation to obs spring how far ahead do the sd springs sit at the front bolt s of the springs
Old Apr 19, 2012 | 02:37 PM
Talyn's Avatar
Talyn
Are you talking about if you install V-codes on the OBS?
Its not much IIRC, like an inch or 2.
Old Apr 19, 2012 | 06:47 PM
crash1's Avatar
crash1
ya v codes /the difference on the front bolt
Old Apr 19, 2012 | 08:33 PM
Talyn's Avatar
Talyn
Neal is the only one I know who's done the V-code upgrade with an RSK.
Old Apr 19, 2012 | 08:50 PM
crash1's Avatar
crash1
ya i just wont to no when an obs sitting there with stock springs and the diff. between one with sd springs...where that lead bolt sits in relation to the obs stock set up
Old Apr 19, 2012 | 09:05 PM
BlueMule's Avatar
BlueMule
SD springs are 4" longer.
Old Apr 19, 2012 | 09:09 PM
Iallwork's Avatar
Iallwork
What does v code mean or what is it?
Old Apr 19, 2012 | 09:20 PM
crash1's Avatar
crash1
so center pin to mounting eye is 4" longer then a obs center pin to mounting eye?
Old Apr 19, 2012 | 09:32 PM
Talyn's Avatar
Talyn
I thought I understood they stuck out further in the front, but the rear mount was the same?
Old Apr 19, 2012 | 09:56 PM
Iallwork's Avatar
Iallwork
My 88-93 SD springs were the same as my 97 f350. are you talking about the front springs?
Old Apr 19, 2012 | 11:10 PM
crash1's Avatar
crash1
ya the diff. in 97 obs to 99 sd
Old Apr 20, 2012 | 08:15 AM
Talyn's Avatar
Talyn
V-codes are different springs bro.
Old Apr 20, 2012 | 08:20 AM
Iallwork's Avatar
Iallwork
ok thank for the info.
Old Apr 20, 2012 | 08:22 AM
Talyn's Avatar
Talyn
V-code is like the ultimate spring upgrade for our OBS trucks.
Longer spring makes for a smoother ride, but there is more work involved.
Send neal97f250 a message about it.
Old Apr 20, 2012 | 08:56 AM
Iallwork's Avatar
Iallwork
Alright, I was just thinking that if they longer they might ride better. I was battling just putting the SD springs in from the 93. I'd try it now that i did this one. I was thinking about getting rid of those front shackles anyway. Boy if they stick out four inches futher in the front they must come out close to the end of the frame.
