OK, Guys..
'88 ford F-250,351W...stock.
do the aftermarket intakes(500 bucks or so)
and aftermarket throttle bodies(300 bucks or so)
do any good with A speed density engine? converting to mass air...then upgrading to A decent mass air...can be spendy!
hell...the K&N filter is 250!
removing the 'puter...and going old school(edelbrock carb, cam, headers, intake) might be easier and cheaper....ideas?
thanks...
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
yes the speed density system will handle those mods. what freaks out a speed density system is radical cams with really low lobe seperation. also you can fab up your own k&n piping system for 60 bucks . do a search for getto fab K&N. if you go with these upgrades you should also address the restrictive exhaust manifolds and the rest of the exhaust system. other wise you will not see the true gains of the intake/throttlebody.
look for another bronco site on the web. it will have it with pictures to. if you email me i will give you the name of the site just cant post it here they get mad
