1978 - 1996 Big Bronco
Mass airflow
Old Jan 1, 2013 | 05:42 PM
Helipilot2's Avatar
Helipilot2
Mass airflow
I'm looking at cold air intakes for my 96 bronco. Some say with mass airflow and others say without. How do I tell if I have mass air flow sensor?
Old Jan 1, 2013 | 06:01 PM
Helipilot2's Avatar
Helipilot2
Ok so I figured out that the 302 went MAF in the early 90s so I do have it. All the intakes are for MFI which doesn't make sense to me since I believe mine is EFI
Old Jan 1, 2013 | 06:05 PM
khadma's Avatar
khadma
Carpenter Local 745
I posted some info in your other thread.
Stock intake works fine with your stock engine.
Old Jan 1, 2013 | 10:15 PM
greystreak92's Avatar
greystreak92
CAI's are a waste of money on these trucks. The research has been done. Insulate the OEM intake plumbing up to the throttle body and you will be better off.
As for the MAF, EFI, MPI alphabet soup conundrum:
EFI - Electronic Fuel Injection is standard on the F-series 1/2 tons (which includes the full-size Bronco model) as of 1987.
MAF - Mass Air Flow is a fuel metering method employed in the mid 90's (late 94+) in conjunction with EFI. (ALL MAF vehicles are EFI).
MPI - Multi-Port Injection is a distinction between having a fuel injector at each cylinder and one (or a pair) of injectors mounted in the throttle body. The latter is known as TBI (Throttle Body Injection). The F-series were never TBI-equipped from Ford.
MAF (continued) Mass Air Flow fuel metering also incorporates SEFI technology. Sequential Electronic Fuel Injection allows each injector to "fire" or release fuel into its respective cylinder individually just as spark plugs would fire individually. Albeit spark and fuel are not triggered simultaneously.
The earlier EFI fuel metering system is often referred to as SD - Speed Density wherein there is still an injector at each cylinder however they are "fired" in banks typically left-side followed by right-side or in the case of the 300 (4.9L) inline 6, injectors 1-3 then injectors 4-6.
bigtoolracing
Jan 3, 2023 04:06 PM
bigred66
Nov 23, 2011 10:15 AM
gungho351
Feb 7, 2009 06:46 PM
carpe_diem
Feb 1, 2004 10:58 PM
Mike 61Ford
Jan 5, 2004 11:58 AM
