anyone running a bendix power steering system?
Old Aug 26, 2005 | 12:07 AM
oldhalftons's Avatar
oldhalftons
Originally Posted by Freightrain
I always forget which mine has? Ok, where's the link to which is which? I know my pump is leaking around pulley. have to fill it up each week now. The inner fender will never rust for sure in that spot!
So far the box itself is in good shape. (with fingers crossed)
there will be about 4" of steering shaft exposed between the column and the box if its a bendix box. the ford box is longer and goes almost right to the column.
Old Aug 26, 2005 | 11:24 AM
dotcentral's Avatar
dotcentral
What pump to use with bendix box
Someone was telling me he didn't think the bendix pump had to be used with the bendix steering box. He said a ford pump, or any pump for that matter would work. I would think that the pump would be calibrated for the box, size of hose (fitting ends), amount of PSI. Anyone got any insight on this?
Thanks for the info so far.
Old Aug 26, 2005 | 04:59 PM
banjopicker66's Avatar
banjopicker66
DC, you must use the Bendix pump with the Bendix box.
The Ford pump is a "slipper" or variable pressure type pump, which has it reduce the pressure as the RPMs increase. The Ford box is designed to oeprate with this setup.
The Bendix system, though, is designed to operate with higher pressures. I inadvertently hooked up a Ford pump when I first installed the Bendix system, and it would not operate properly. It felt like there was no power steering at rest, and it was barely there at freeway speeds.
Could it have been a bad pump? Possibly, but I never really determined it.
Just my experience.
Old Aug 26, 2005 | 07:15 PM
dotcentral's Avatar
dotcentral
Thanks Banjopicker. Makes sense to me, just wanted to get some feedback on it.
Old Aug 26, 2005 | 09:14 PM
oldhalftons
you can any ford pump except the aluminum/plastic pump. the saginaw or the pre-78 steel pump.
Old Aug 27, 2005 | 12:30 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
The round can pump is a Thompson pump as what powered a Bendix box. Same pump with a Ford box is not a problem.
.....=o&o>.....
Old Aug 28, 2005 | 07:49 AM
Steve Ga's Avatar
Steve Ga
Originally Posted by Beemer Nut
Any takers on a low mileage (68K) tight Bendix box and pitman with 2 seal rebuild kits from Ford less the input shaft seals? $100 you pay shipping, core alone is $150 to $250 by rebuilders plus their rebuild fee? Good for a manual to power convert for pre 68 as you don't have to change column, pitman and column to run a Ford box.
.....=o&o>.....
I have a 67 F100 with 240 six,would like to have power steering.Is the bendix just a drop in?My e-mail is srhinehartdev@aol.com
Old Aug 28, 2005 | 10:21 PM
Chromepro's Avatar
Chromepro
I would be interested in the box if its still available.
Old Aug 29, 2005 | 06:30 AM
jowilker's Avatar
jowilker
Gentlemen, Please use the email function to contact B nut.
John
Old Aug 29, 2005 | 11:03 AM
"Beemer Nut"
Jowilker, it's my mistake I stated I had a Bendix box, bad judgement on my part, sorry. Others please PM, thanks Carl.....=o&o>.....
mgermany
2009 - 2014 F150
34
Jun 22, 2009 09:00 PM
Buckarcher
Jan 15, 2003 09:42 PM
GMFDBob
May 8, 2002 12:25 AM
Kenny
16
Nov 29, 2001 10:18 PM
dinosaurfan
Jul 17, 2001 12:57 PM
