Did you know....
Old Jan 13, 2003 | 02:20 PM
Buckarcher's Avatar
Buckarcher
Did you know....
Old Jan 14, 2003 | 09:44 PM
rsincla's Avatar
rsincla
Did you know....
Don't really want to start another flame war regarding gun rights, but I found something really interesting the other day.
Did you know, according to US code Title 10, Section 311, that all US male citizens between the ages of 17 and (with some exceptions) 45 are considered militia members? Kind of blows a hole in the pro-gun-control crowd that argue, "Unless you're part of an organized militia, the 2nd amendment doesn't apply to you", don't it?
See the entire text here:
http://www4.law.cornell.edu/uscode/10/311.html
Rory
'65 F-250 Camper Special
'68 MGB
Old Jan 14, 2003 | 11:32 PM
FordRancher's Avatar
FordRancher
Did you know....
That's some cool info. Wish I had found that about 3 years ago when I did my senior term paper on gun control. I found out a lot of good stuff doing that paper too. I kinda wished I had researched the pro-gun controll side better to see if I could argue for it just for the sake of debate, but I'm against gun control (except for properly using guns) so I focused on it. It's scary the way some people want to take away our Constitutional Rights. :-X23
Old Jan 14, 2003 | 11:41 PM
Quadiquizm's Avatar
Quadiquizm
Did you know....
Gun Control - all I can say about that is that atleast you guys don't have the big mess we have up here. Check out the Billion Dollar "Mess":
http://cbc.ca/storyview/CBC/2002/12/03/auditor021203
Keep it Rubber Side Down!
Old Jan 15, 2003 | 06:46 PM
flyboy2610's Avatar
flyboy2610
Did you know....
When guns are outlawed, only outlaws will have guns.
Old Jan 15, 2003 | 08:17 PM
1956MarkII's Avatar
1956MarkII
Did you know....
I was behind a Subaru the other day that had a rainbow bumper sticker on one side, and this on the other side of the tailgate:
"If gays are outlawed, then only outlaws will have good taste."
I hope the driver didn't see me laughing- he was bigger than Hulk Hogan!
Old Jan 15, 2003 | 09:05 PM
FXSTC's Avatar
FXSTC
Did you know....
Here is my opinion on Gun Control.
When standing in the Weaver Stance:
1. Do not "push pull" too hard as a lot of force will cause the gun to waver.
2. Try to drop your elbows so they intersect the nipple lines of your body (not touching the nipples but on the same plane)- this allows for "triangular theory" and results in a very strong stance which is thoroughly rooted to the ground.
3. The weapon and your "aiming" eye should be on the center line of your body (leung yi mah).
4. Your forward foot should be parallel to the line of fire. ***NOT*** pointed at the same spot on the target but parallel to the barrel of the gun (lok mah).
5. The elbow of the arm of the front hand should not intersect the planes formed in space perpendicular to the ground by the center of the torso (dan tien) or the forward knee (sam dim yat sin).
6. The rear arm elbow and front knee should be the same distance from the body (yi gi kim yeung mah).
7. Do not focus on the target-- be aware of the target and have the target as your true intent but be more aware of the alignment of the sights (lin tao).
This is very brief but if you follow these pointers you should have decent Gun Control.
When on two wheels-
FXSTC
Mesa- AZ
2003 F-350 V10
Old Jan 15, 2003 | 09:28 PM
wabiker's Avatar
wabiker
Did you know....
Well said FX...well said....
Old Jan 15, 2003 | 09:42 PM
78 4X4 Thunder's Avatar
78 4X4 Thunder
Did you know....
Gun Control means hitting your target!
1978 F150 Custom 4x4
300-6 w/ 4.11's
3spd + Chevy pulling gear
BFGoods 32x11.50s
Chevy symbols in the grill
Dodge symbols in the muffler
Black is oil
Red is tranny
Green is antifreeze
So what are the yellow puddles under Chevys?
CampSpringsJohn
Mar 9, 2013 08:38 AM
Phillyrube
26
Feb 8, 2010 06:48 PM
Ripsnort
22
Feb 25, 2004 10:06 PM
Dayton
105
Jul 25, 2002 08:55 AM
