Alignment Cam?
Old Aug 21, 2005 | 03:41 PM
MARQ1994's Avatar
MARQ1994
Alignment Cam?
Mechanic can't align my 94 F150 because I need new cams? What is a alignment cam...maybe by another name?
Old Aug 21, 2005 | 05:39 PM
jamiesan's Avatar
jamiesan
depending upon application, an alignment cam, for a 98 moutaineer for instance, is basicly a bushing with the center hole... off center. this way it can be turned in place & then locked in place with a nut to correct for say a saggy torsion bar. Or, on a lift kit application, there are " cammed" washers which also have an off centered hole to pretty much do the same thing. Hence, in this case CAMMED = eccentric, or off centered. What is your application?
Old Aug 22, 2005 | 05:28 PM
MARQ1994's Avatar
MARQ1994
1994 F150 XLT...just had alignment done 6 months ago...now mechanic tells me both "cams are out...BTW thanks for the info
Old Aug 23, 2005 | 01:39 PM
jamiesan's Avatar
jamiesan
Well, that sounds disgustingly familiar. In march I had my wife's mountaineer aligned at Sears. They installed a "cam kit" to align it. 5 mo.s later there was a clunk in the front end, the cam's bolt/nut was loose. The ones that come with lift kits provide lock nuts, this kit from sears didn't. I think it was just "shoddy" workmanship on their part, which is why I like to do as much as I can myself. Hope you got a warranty on the alignment, and tell them to install & torque locknuts. Let'em know that you know what's the right way.
wildcat99
2004 - 2008 F150
Apr 9, 2009 01:35 PM
Crazy Canuck
Feb 23, 2004 11:03 PM
ROKRAWL
Aug 20, 2003 07:25 PM
Bubba Shrimp
Jun 13, 2003 04:35 PM
