Sponsored by: Real Truck
Front end alignment
Old Aug 19, 2003 | 10:11 PM
ROKRAWL's Avatar
ROKRAWL
Front end alignment
I just had my 250 aligned and the tech said he couldn't get it exactly correct because it is missing some "cams". Anyone know what these "cams" are? if they are neccessary? and where to get them?
thanks
Old Aug 19, 2003 | 10:22 PM
just_brian's Avatar
just_brian
Front end alignment
Sorry, don't know what the cams are. But now you've got me curious - what are they? and why are they "missing"?
Old Aug 19, 2003 | 10:53 PM
jetjock16's Avatar
jetjock16
Front end alignment
they are refering to the cambered spacers that go on top of the top ball joint to make camber adjustments.... take it to a more reputable place and they should hook you up... try going to a place that works on semi's and big rigs, they always have equipment that can handle the big superduty.
Old Aug 19, 2003 | 11:27 PM
Donahoe's Avatar
Donahoe
Front end alignment
There is a company called Engells that make all the cams for pretty much ever car or truck on the road... Try a web search for engells or some differnt spellings that sound the same... Use alignment cams as well in your search...
Good luck.
Old Aug 20, 2003 | 10:21 AM
Yeti's Avatar
Yeti
Front end alignment
Also, I believe Superliift offers cams, and larger than what can be had in oem sizes.
Old Aug 20, 2003 | 07:25 PM
popkorn's Avatar
popkorn
Front end alignment
I would hope my 02 sd would not be so far out it needed ball joint spacers! Older F250's with TTB needed cams, but a new straight axle? I would get A second opinion, if the same, go back to the dealer.
wildcat99
2004 - 2008 F150
Apr 9, 2009 01:35 PM
MARQ1994
Aug 23, 2005 01:39 PM
Crazy Canuck
Feb 23, 2004 11:03 PM
Bubba Shrimp
Jun 13, 2003 04:35 PM
