Sponsored by: Kumho
Adjuster cams for front-end alignment?
Old May 31, 2003 | 12:01 PM
Bubba Shrimp's Avatar
Bubba Shrimp
Just put new tires (stock), steering column and steering box on my 91 F150 2WD. Took it to Ford to do a front-end alignment and they called after a couple of hours and said that it needed new adjuster cams as they couldn't correct the alignment with the present cams.
They said this happens a lot and on the Chevy trucks the cams are welded on which creates a big problem for the Chevy owners.
They want $40.00 for the cams and 1 Hr ($50.00) to put them on before they will do the alignment. They want $49.95 for the alignment, making a grand total of $139.95.
Not having any choice or a clue if this was correct or not I told them to go ahead and do it.
Did I just get hosed or does this sound right? The said the alignment was 1.5 degrees off, which (they said) was a lot.
Old May 31, 2003 | 11:51 PM
mrshorty's Avatar
mrshorty
Sounds about right. I'm more familiar with the 4x4 version of Ford's TIB front end. They use a bushing around one of the ball joints on each side to correct camber and sometimes caster. When the camber is off, it is corrected by replacing that bushing with a different one. When I priced the bushings, they ran about $20 a piece, and 30 minutes a side should be reasonable for someone with the know how and appropriate tools to pull the front end apart and replace the bushings.
Old Jun 1, 2003 | 09:15 AM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
i think i would have had them just put new springs on the truck , the springs sag over time and the ride height change throws the camber off.
Old Jun 13, 2003 | 04:35 PM
DCN's Avatar
DCN
Just had similar problem with my 96 F-150xlt, 4x4 shortbed, in line 6. 95,000 miles Had four shocks and front springs done. Rode great but noticed front wheels looked pigeon toed. Took for alignment and was told new 2 degree bushing had to be installed. Total parts and labor $240.00.
yourofficesupplier
Sep 11, 2016 06:17 PM
F-ReV
Jan 21, 2016 12:03 PM
94GreenTruck
1997 - 2003 F150
May 16, 2015 08:25 AM
johnmel59
Feb 26, 2015 03:41 PM
turnkyle
20
Sep 1, 2014 08:28 PM
