Heavy hauling
Old Nov 8, 2005 | 05:46 PM
  #31
MBBFord's Avatar
MBBFord
Originally Posted by EricJ
changing the tire size defeats the purpose of regearing.
So your trying to tell me you can tow better with 27" tires and 4.10 gears with out shooting the RPMs out the roof while travleing down the high way?
I promise you if you had 31-33" tires you could tow pretty good with 4.10s with good Highway RPMs.
Old Nov 9, 2005 | 06:38 AM
  #32
Pre'80's Avatar
Pre'80
Originally Posted by Redneck'n
Have a '79 F-250 SuperCab and used it to pull a 28' Gooseneck with about 12k in hay on it all the time. It has a 460 with a C-6, Dana 60 rearend with 3.73 gears/ open diff.
Other than using a lot of gas, it does just fine.
This may be true, it's not legal. So, in order to make it legal, the truck must be improved then recertified. DOT won't recertify a stock truck to haul more weight than the manufacturer listed it at. I have a recertified truck. It's a '79 F-350 DRW recertified to 15,000lbs GVWR
Old Nov 9, 2005 | 06:44 AM
  #33
Pre'80's Avatar
Pre'80
Originally Posted by okwaho1650
so whats the max for a 77 f250 2wd crew cab 4.10 gears
'79 is 7000lbs conventional, no listing for 5th wheel. 14,000 GCWR. '77 should be close to the same.
Old Nov 9, 2005 | 06:56 PM
  #34
perky's Avatar
perky
Originally Posted by GeorgiaTriumph
And some serious lack of grammar.
Did not know this was a english class
Old Nov 9, 2005 | 08:09 PM
  #35
Redneck'n's Avatar
Redneck'n
I never said it was "legal". If it helps, I can always say I didn't know any better since when they did my title, they made it as 15,000 GVWR for some reason.. I don't know how or why that happened that way.. The truck is stock.
We generally are only hauling that kind of load right around the north side of town. Mostly 10miles from A to B.
Old Nov 13, 2005 | 10:39 AM
  #36
T.R.Bauer's Avatar
T.R.Bauer
The F-250's especially the ones with the full floating dana 60 are pretty darn strong. I have a wonderful 78 f250 4x4 that has pulled 12,000 (plus) pounds very often. This part is a little sick looking back, while hauling 12000 pounds on several occasions I have about 3000 pounds of tile in the back. I never had any trouble with doing any of this. The trailer had good brakes, a had an EQ hitch, and the truck had air bags. Also, the truck is in good shape. In fact, the prior owner used to pull his 36 foot 5th wheel with it all the time.
Old Nov 13, 2005 | 02:44 PM
  #37
Pre'80's Avatar
Pre'80
Hehehe, we do the same thing. But only for a half mile on the road. We hook a 3/4 ton Chev to a 34' gooseneck and haul 14-16 6x5's. Fortunately the sherriff doesn't come around. Not sure if he would say much anyway's, we own all the land in the area except for one small 80 acre farm. The road pretty much goes through our farm.
Old Mar 3, 2013 | 05:10 PM
  #38
old blue beast's Avatar
old blue beast
Im tryin to make a good heavy hauler myself. Not extreme, but enough to be comparable to a newer F-350.
So far ive swapped my D70 rear to a 94' 10.25 Sterling out of a F-350 Dually, 4.10 gears.
Next would be the big change. Built 7.3l IDI Diesel pushin roughly over 350hp... Hopefully... backed by a ZF-5 with HD Clutch and Gear Vendors U/O/D.
Suspension consists of Airlift 5000 Air kit in the rear and a Timbren Kit in the front to handle the weight of the diesel.
For hitches, the rear bumper hitch is goin to be a Curt Class V. In the bed will be a Husky 26K W 5th wheel hitch.
Yur F-250 will need a lot to handle 15,000lbs. Driveshaft, Engine, Tranny, Suspension, Rear Axle. Hope this helps some
Old Mar 3, 2013 | 05:52 PM
  #39
VocaTexas's Avatar
VocaTexas
Blue Beast, you realize the thread you resurrected is over seven years old, right?
Old Mar 3, 2013 | 06:43 PM
  #40
privateer, eh's Avatar
privateer, eh
I just peed myself laughing, thanks, I needed this after shoveling out my work area.
Old Mar 3, 2013 | 07:32 PM
  #41
old blue beast
Wow.... ok... I feel like a retard. Ill check the dates next time I respond to something... Thanks
Old Mar 3, 2013 | 08:32 PM
  #42
privateer, eh
Don't let it bother you. The key to being perfect is to make perfectly human mistakes, when you make silly mistakes you become perfectly human. As any selfmade successful person can tell you " it only took 5000 mistakes to get the program right".
Old Mar 3, 2013 | 09:31 PM
  #43
Scot's Avatar
Scot
There was a thread on Pirate4x4 8 years ago or so from a guy that flipped an overloaded toy hauler and killed others. The insurance paid to its max and left him with a million dollar plus judgement that he could start paying when he got out of prison for the criminal part.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Roachfood
Mar 11, 2002 10:21 PM
