Crackling under acceleration
Old Aug 18, 2005 | 08:23 PM
fire19's Avatar
fire19
Question Crackling under acceleration
I have 2000 F-350 CC Dually 7.3 Diesel approx 113000 miles on only mod is the Kwik air filter. I have just noticed that when the truck is under hard accel I hear a crakling sound coming from under the hood. Does anyone have any Ideas ???
Old Aug 18, 2005 | 08:27 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
could it be described as a hissing noise? (like a air pressure leak?) thats typical of the kwik filter, because i have heard it when under heavy acceleration. also you should hear a noise similar to a blow-off valve on a rice burner changing gears-when you let off the throttle or change gears with an automatic tranny. i notice the most hissing shifting from 3 to OD with a constant pedal. ive drug the hissing sound out for 7 seconds once before
Old Aug 18, 2005 | 08:38 PM
fire19's Avatar
fire19
It is a crackling sounds like arcing sound like when you are welding.
Old Aug 18, 2005 | 08:41 PM
PowerstrokeJunkie
hmm i refer to that as "bacon sizzling" i have never heard of a arcing sound when driving, hmm maybe someone more knowledgeable will chime in here soon....
Old Aug 18, 2005 | 09:03 PM
Max1775's Avatar
Max1775
May have an intercooler boot leaking or something similar to that. They can make some really odd noises.
Max
Old Aug 20, 2005 | 06:42 PM
MobeyDick's Avatar
MobeyDick
What kind of oil are you using? How many miles on that oil change!
Old Aug 21, 2005 | 07:24 PM
fire19's Avatar
fire19
I have had the Ford Dealership do all the oil changes @5000 miles Using Motorcraft oil
Old Aug 21, 2005 | 10:03 PM
MobeyDick's Avatar
MobeyDick
No matter who does the oil changes YOU need to make sure it's CI-4 Rated. It sounds like the same problem I was having. Change the Oil and Make sure it's CI-4 rated.
rvpuller
6.2L V8
May 27, 2014 04:29 PM
Gravesdigger
All Things Towing
16
Sep 1, 2012 08:36 PM
jostrowski
Mar 27, 2008 11:42 PM
phoneman91
Jun 17, 2007 11:22 AM
EBaker
1983 - 2012 Ranger & B-Series
Jul 26, 2005 09:44 PM
