Power window problem
Old Aug 16, 2005 | 07:07 AM
johare's Avatar
johare
1999 Ranger X-cab XLT
The power windows on both sides quit working. THe fuse under the hood seems fine but there is no power to either switch in the doors. Any ideas? Is it likely a relay?
Old Aug 16, 2005 | 08:00 PM
Ken00's Avatar
Ken00
There are two relays in the circuit, the delay relay and the battery saver relay, any other problems?
Old Aug 17, 2005 | 06:44 AM
johare's Avatar
johare
Nothing else is effected that I have noticed. Only the windows.
Old Aug 17, 2005 | 06:47 PM
Ken00's Avatar
Ken00
This is the list of things to check, I'll be glad to post the details on anything you can do yourself.
Glass, Frames and Mechanisms
PINPOINT TEST A: ALL POWER WINDOWS ARE INOPERATIVE
² A1: CHECK THE IGNITION STATES — MONITOR THE GEM PID IGN_GEM
² A2: RETRIEVE THE DIAGNOSTIC TROUBLE CODES (DTCS)
² A3: CHECK THE BATTERY SAVER RELAY COIL CIRCUIT — MONITOR THE GEM PID BATSAV
² A4: CHECK THE ACCESSORY DELAY RELAY COIL CIRCUIT — MONITOR THE PID ACCDLY
² A5: CHECK THE VOLTAGE TO THE ACCESSORY DELAY RELAY COIL — CIRCUIT 705 (LG/O)
² A6: CHECK THE ACCESSORY DELAY RELAY
² A7: CHECK CIRCUIT 1004 (LB/R) FOR OPEN
² A8: CHECK THE ACCESSORY DELAY RELAY
² A9: CHECK CIRCUIT 1004 (LB/R) FOR SHORT TO POWER
² A10: CHECK POWER DISTRIBUTION BOX MAXI-FUSE 4 (20A)
² A11: CHECK THE VOLTAGE TO THE ACCESSORY DELAY RELAY SWITCH — CIRCUIT 170 (R/LB)
² A12: CHECK THE ACCESSORY DELAY RELAY
Old Aug 18, 2005 | 02:56 PM
johare's Avatar
johare
Ken,
It turned out to be the "one touch power window relay (a $10.00 item). Apparently all the window power routes through this relay so when it went bad the circuits received no electricity. Fixed now! Thanks for your suggestions.
Jerry
Old Aug 18, 2005 | 07:47 PM
Ken00's Avatar
Ken00
Glad to hear you found the problem.
Old Aug 19, 2005 | 04:35 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Originally Posted by johare
Ken,
Jerry
Out of curiosity, where is this relay located?
Old Aug 21, 2005 | 09:26 AM
johare's Avatar
johare
Cowboybilly,
I am not sure. i had a dealer replace it. I wish I had asked so if it happens again I can do it.
Jerry
Old Aug 21, 2005 | 09:55 AM
Rockledge's Avatar
Rockledge
Bill (and Jerry), I think it's in the relay box which is located underneath/behind the driver's side instrument panel, to the right of the steering column.
Old Aug 21, 2005 | 10:03 AM
MazdaRangerGuy's Avatar
MazdaRangerGuy
I fixed one the other day... relay was in the drivers door, but this was a 92? explorer? I doubt it's in the same place on this one...
Also windows worked fine, except you had to hold the button down to lower drivers window all the way.
juliomad
1997 - 2003 F150
May 22, 2017 07:28 AM
blazinjames
Mar 3, 2017 10:46 PM
wagoner
2015 - 2020 F150
Oct 28, 2016 11:53 AM
wickware
Sep 15, 2004 02:33 AM
djyngs
Apr 13, 2002 07:53 PM
