Sponsored by: Real Truck
Help..Can't Find PCM code
Old Aug 13, 2005 | 01:41 PM
Stang281's Avatar
Stang281
I need to find my PCM code (the guy said it was a 4 digit code). I have a 2005 F-250 Super Duty V10 6.8L. Any help would be greatly appreciated. Thank you!
Old Aug 13, 2005 | 02:20 PM
captchas's Avatar
captchas
Guest
first off welcome to FTE the best ford truck site on the web.Please take some time and read the guide lines and each areas read firsts to help guide you properly though our site.
Now as to your ?. look up at the lip of the fire wall under the the rubber hood gasket on the right passenger side of the motor compartment. you will see the pcm bolted into the firewall and on it is 3 sets of numbers. the one you need is a 3 letter and one number code.
My 05 v10 is brv0 for the code for a example
wlihntr's Avatar
wlihntr
on the older trucks its on the front of drivers inside door jam, near where the hinges are, towards the front fender. it is on a white sticker. dont know about the new ones
Old Aug 13, 2005 | 02:27 PM
Stang281's Avatar
Stang281
Thanks everyone. Site rocks by the way. Sorry I didn't do an intro yet. Got in a bind here. Oh...will my connector be under the dash or in the engine compartment also (to hook up a tuner etc..) Thanks again!
Old Aug 13, 2005 | 02:51 PM
captchas's Avatar
captchas
Guest
it's under the dash towards the middle just over the hump but a little to the left of center. sct is the way to go . good luck.
Firefighter 1406
25
Jan 29, 2020 10:26 AM
newstang
Jul 11, 2013 02:41 PM
redman84
Mar 8, 2011 11:28 AM
Lead Dog
Computer Chips & Tuners
Aug 14, 2008 07:58 AM
bigred66
Sep 1, 2005 08:40 AM
