Engine codes and PCM
Old Aug 31, 2005 | 01:41 PM
bigred66's Avatar
bigred66
I recently recieved an engine code of
543 Fuel pump secondary circuit failure Battery to control module Does anyone know if I need to replace a battery on the PCM or the whole PCM? Any help will be greatly appreciated, thanks
Old Aug 31, 2005 | 01:59 PM
andym's Avatar
andym
Can you post in plain text? There's a lot of extra stuff in your post that makes it hard to read.
Can you also tell us anything about the vehicle? Year, model and engine would be great.
Old Aug 31, 2005 | 02:27 PM
EPNCSU2006's Avatar
EPNCSU2006
The computer monitors the switched side of the relay; the wire that goes to the fuel pump to make sure that it is getting voltage and basically verifies that the fuel pump relay is working. It could be an intermittent fuel pump problem or something else. I would clear it and see if it comes back. Nothing really needs to be replaced just yet. I think also that this code can be set by switching tanks while the truck is running, but I don't know for sure.
Old Aug 31, 2005 | 04:05 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Fixed ....and Welcome to FTE
Old Sep 1, 2005 | 08:40 AM
bigred66's Avatar
bigred66
thanks Tim
mlj1st
Nov 1, 2016 05:27 PM
Robs67rs
1997 - 2003 F150
Sep 18, 2015 01:32 PM
redman84
Mar 8, 2011 11:28 AM
jaykaran
17
Feb 14, 2011 12:55 PM
zempman
Computer Chips & Tuners
Sep 12, 2005 02:45 PM
