I need to find my PCM code (the guy said it was a 4 digit code). I have a 2005 F-250 Super Duty V10 6.8L. Any help would be greatly appreciated. Thank you!
first off welcome to FTE the best ford truck site on the web.Please take some time and read the guide lines and each areas read firsts to help guide you properly though our site.
Now as to your ?. look up at the lip of the fire wall under the the rubber hood gasket on the right passenger side of the motor compartment. you will see the pcm bolted into the firewall and on it is 3 sets of numbers. the one you need is a 3 letter and one number code.
My 05 v10 is brv0 for the code for a example
on the older trucks its on the front of drivers inside door jam, near where the hinges are, towards the front fender. it is on a white sticker. dont know about the new ones
Thanks everyone. Site rocks by the way. Sorry I didn't do an intro yet. Got in a bind here. Oh...will my connector be under the dash or in the engine compartment also (to hook up a tuner etc..) Thanks again!
