reverse lights
Old Aug 10, 2005 | 04:45 PM
Tranoham's Avatar
Tranoham
I have a 79 F-150 and the reverse lights don't work and the brake lights don't work i was wondering if any one could give me some info on how to get these lights working again.Without tearing all the carpet out and recking something. Thank you for your time from a dedicated member
Old Aug 10, 2005 | 06:54 PM
Tranoham's Avatar
Tranoham
full size van and want to fix it up.??????
I have a 1979 ford full size van and my reverse lights don't work all the rest do but the reverse lights don't what would be an easy and afordable way to fix this problem.If anybody wants to give me some info on how to pimp my ride i'm open to suggestions remember it's a full size van with lots of room. thanx for the time.
Old Aug 10, 2005 | 07:12 PM
Franklin2's Avatar
Franklin2
If the reverse lights are the only thing out, I would crawl under the van and unplug the switch on the side of the tranny. You should have two red/blue wires. Ignore these. If you take a small jumper wire and jump the two remaining wires, the reverse lights should come on if the key is in run.
If they come on, the switch on the tranny is bad.
If they don't come on, it may be a fuse or something wrong with the sockets in the back.
Old Aug 12, 2005 | 08:45 AM
Tranoham's Avatar
Tranoham
I will try that and let you guys know how it works
jmuenchow
Jun 1, 2018 03:45 PM
Dreadhead
Oct 6, 2015 05:30 AM
Eman1022
13
Apr 25, 2014 09:23 AM
mtondreo
Dec 23, 2009 06:26 AM
Wakeboarder141
1978 - 1996 Big Bronco
Mar 15, 2003 11:31 PM
