1978 - 1996 Big Bronco
Reverse lights no worky
Old Mar 15, 2003 | 04:16 PM
Wakeboarder141's Avatar
Wakeboarder141
My reverse lights don't light up when I go into reverse. I checked the bulb and it's fine. The fuse under the hood is also fine. What else can I check? Thanks.
Old Mar 15, 2003 | 06:47 PM
Chrisvte's Avatar
Chrisvte
You might want to check your neutral safety switch and your multi-function switch. What year is your truck and what type of transmission do you have??
Old Mar 15, 2003 | 06:56 PM
Wakeboarder141
It's a 93 Bronco Custom with the E4OD
Old Mar 15, 2003 | 10:43 PM
Wakeboarder141
How do I check those switches? I am still new to this.
Old Mar 15, 2003 | 11:31 PM
steve83's Avatar
steve83
Find the diagram in the Haynes manual and test for continuity or voltage at the appropriate switch wires. On an E4OD, it's called the MLP (Manual Lever Position sensor), but it's just a glorified backup switch on the side of the transmission where the cable attaches.
E55 Bulldog
Mar 24, 2016 10:21 AM
Sam's The Man
Mar 6, 2016 07:28 AM
AliceSML79
Feb 8, 2016 06:43 AM
enil01
Jan 5, 2015 06:06 AM
dsauka
Oct 27, 2004 12:17 PM
