Overheating...need help
Old Aug 9, 2005 | 03:22 PM
FireInspector's Avatar
FireInspector
I have a 89' F-150 4x4 I6 4 speed that continues to run hot either when idleing or on the highway. I have replaced the water pump, thermostsat, fan clutch and shroud. It also has a new radiator and have checked the timing. Is there something that i'm overlooking? Please help
Old Aug 9, 2005 | 03:49 PM
4x4fordtrkn's Avatar
4x4fordtrkn
Did you get all the air out of the system?
Old Aug 9, 2005 | 09:30 PM
95_4x4_jay's Avatar
95_4x4_jay
Temperature sensor??
Old Aug 10, 2005 | 07:24 AM
FireInspector
4x4fordtrkn, thanks for the reply, i'm sure there is no air in the system but concerned that the cat needs replacing. Truck has 127k on it. It does not overheat around town, only idle and hwy speeds. Could the cat cause this to happen?
Old Aug 10, 2005 | 09:07 AM
NM5K's Avatar
NM5K
I guess it's possible, but I would think it would do it at
city speeds also, if it did it at idle, and highway both...
Are you sure you are actually overheating? Might be a flaky
senser, etc... MK
Old Aug 10, 2005 | 10:23 AM
FireInspector
NM5K, she's definately running hot, on a 12 mile ride down the interstate it will start spewing coolant out of the overflow. I'm stumped.....
Old Aug 10, 2005 | 11:35 AM
IceWagon's Avatar
IceWagon
Overspilling could also be caused by just overfilling the radiator. Hot liquid expands and needs a place to go. Do you have a coolant expansion tank, is it working properly. If not equipped with tank make sure you leave at least one inch below top of radiator for expansion.
Old Aug 10, 2005 | 11:54 AM
FireInspector
Yes, the coolant overflow tank is there. I really don't think it's a coolant problem but more of something else preventing it from keeping cool. Thanks in advance
Old Aug 10, 2005 | 12:32 PM
johnsonswamp's Avatar
johnsonswamp
Check you're spark plugs and see if one or all of them are dry, ashy, or white. A lean condition will cause over heating bad. Could be a small leak on the intake side.
Dose it seem to have lost any power? A bad cat will prevent the exhaust from flowing, thus causing the exhaust to "plug up" the engine which will over heat it or most times it will not run at all if it's that bad.
Old Aug 11, 2005 | 12:55 AM
-jeremy's Avatar
-jeremy
check the bottom radiator hose. If it's soft, it's possible that the pressure from the coolant being sucked out of the radiator could cause it to squeeze together causing a blockage of flow.
just a thought
Old Aug 11, 2005 | 03:34 AM
NM5K's Avatar
NM5K
Hummmm... Weird, being most culprits have been replaced...
Yep, a collapsed bottom hose could do it. Wonder if the "new"
stat is ok? Probably, but being new is no sure thing. As far as
the cat, you could use a vacuum gauge to check that. With the
gauge on a good strong port, raise the RPMs and see if the vacuum
recovers fast. If so, it should be ok. But if it "hangs" for a while,
and then slips back, it might be clogged. As far as lean running,
it will make the chamber temps much hotter, etc, but I'm semi dubious if that would cause the extreme overheating you seem
to be having. In the past cases of lean burning cars I've worked
on with white plugs, none overheated to the extent of what he is
seeing. I guess it could happen though...I've seen stranger things. Dang...At this point, I'm starting to question the water
pump, and stat, being the radiator is new. I wonder what would
happen with the stat yanked as a test.... Not that I would leave it that way... Driving with no stat is a bad idea... If I think of anything else, I'll pass it on...You right, this is kinda weird... MK
Old Aug 11, 2005 | 12:42 PM
FireInspector
Thanks for your input and knowlegable opinions, I will keep working on a solution and will share what gets her to run cool. Thanks again
Old Aug 11, 2005 | 04:42 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
You could haqve gotten a bad thermostat out of the box. For that matter I've had the bad luck of getting a bad water pump out of the box too. Wouldn't pump the water.
I always check my new thermostats with a candy thermometer and a pot of boiling water. If it fluctuates more than + or - 1 degree either way I get another one etc...
You can check the water pump or a clogged radiator as well by taking off the radiator cap on a cold engine, warm it up to normal temp and rev the engine and notice if the water gets sucked down into the engine and notice the flow of water returning. Be careful of splashing coolant during this test. If there isn't any flow on a warmed up engine, there is a blockage of some kind, the pump is not working or the thermostat isn't opening.
Hope this helps.
Old Aug 11, 2005 | 10:51 PM
big_rig_ford_2's Avatar
big_rig_ford_2
Check to make sure the radiator cap isn't worn out (vacuum test).
Check for excessive water vapor in exhaust. Check oil for whiteness and coolant for traces of oil, all signs of a seeping head gasket.
kwrules
1983 - 2012 Ranger & B-Series
Dec 9, 2012 07:56 PM
784x4
Jan 25, 2006 03:30 PM
DmanFord
May 7, 2004 11:02 AM
dvsmnstr
Dec 20, 2003 03:05 PM
