View Poll Results: Max Timing advance for the FE446
less than 34
0%
34-35
37.50%
36-37
0%
38-39
50.00%
40-41
0%
42-43
0%
44-45
0%
greater than 45
12.50%
Multiple Choice Poll. Voters: 8. You may not vote on this poll
Total Timing Advance
Old Aug 9, 2005 | 06:09 PM
rusty70f100's Avatar
rusty70f100
Woohoo! Now I have the information I need!
I'll compute what the deck clearance is, based on your numbers. It would have been best if you had measured it, but this will have to do:
10.17" deck height, subtract
4.125/2 = 2.0625" crank throw, subtract
6.7" rod, subtract
1.388" compression height piston, leaves
.0195" deck clearance! We'll round it up to the nearest thousandth, so .020".
So we add your .041" head gasket and come up with .061" quench space. This is not optimal, so you'll need a little more timing.
See this article from KB.
Then read this one.
And finally this one.
Based on this, I'll err on the side of safety and vote somewhere around 38 degrees total. In reality with your quench space you may even need a little more. Next time you have the heads off, put in some .020" thick head gaskets. You'll get more compression, more power, less pinging, AND need less timing.
Old Aug 9, 2005 | 06:20 PM
gtex's Avatar
gtex
6.7" rod, subtract
Then read this one.
thanks Kurt. That's all good information. can you confirm what my static CR is with that setup?
Old Aug 9, 2005 | 06:53 PM
rusty70f100
Sure. We'll assume a few things:
1. That the Edelbrock head chambers are in fact 72cc's as advertised,
2. That you actually do have the .020" deck clearance that I calculated above,
3. That the piston dishes actually do come to 15cc's,
4. That 4.4" is the average bore diameter of the head gasket.
I'll use the calculator on KB-Silvolite.com. Very good site BTW.
With your current setup, it calculates out to 9.916:1 static compression, and 8.684:1 dynamic compression with the 521 roller cam.
If you put in the .020" thick Mr Gasket head gaskets, you'd get 10.451:1 static compression ratio, and 9.145:1 dynamic. I really think you could get away with it. With a 541 roller cam, it'd really work good...
Edit: With the 541 roller cam, you'd have 8.584:1 dynamic compression ratio with the .020" head gaskets. If you're looking for an upgrade, this is it. Cam and head gaskets...
Old Aug 9, 2005 | 08:15 PM
gtex's Avatar
gtex
Kurt, you've joined the ranks of Scouder and DF with the "Bigger Cam, Bigger Cam" approach.
Any idea what that does to the vacuum and idle? Remember, I'm pushing a 4600lb truck with PB, PS, AC etc.
Old Aug 9, 2005 | 08:25 PM
Bear 45/70's Avatar
Bear 45/70
Stock 428 AND 427s ran 38 degrees total and they weren't horsepower whimps.Running the 93 octane, you should have no problem with pinging or detonation.
Old Aug 9, 2005 | 08:33 PM
rusty70f100
Well, you have the higher stall TC, what are you worried about? Vacuum goes down, idle RPM goes up, miles per gallon goes down. When you increase the idle RPM, vacuum goes back up. If you set the timing at idle a little higher, it helps with idle vacuum.
Old Aug 10, 2005 | 09:14 AM
strokster's Avatar
strokster
That's all extremely valuable information. Now to digest, re-read and apply. Thanks for taking me back to school!!!
Old Aug 10, 2005 | 09:53 AM
gtex's Avatar
gtex
I didn't see your entry on the chart. I know you're a chart person!
juanone
Engine Swaps
Aug 17, 2014 10:56 AM
rbaruffi
Nov 26, 2011 05:25 AM
LAH460
17
Sep 24, 2004 09:08 PM
81f2504x4
Apr 26, 2004 03:10 PM
TorqueKing
Apr 29, 2002 08:12 PM
