Pididle !!!
Old Aug 3, 2005 | 03:56 PM
Brown Beast's Avatar
Brown Beast
Pididle !!!
My driver side headlight that, on low beam only, soetimes works-sometimes does not. Allways works on high beam. Replaced bulb twice. Same result both times. Any ideas? hitting it with a sledgehammer does not seem to work. Nor does the ball-peen hammer. My next tool is going to be a .270 WIN. or a 20ga slug. This frack'n thig is pissing me off.
Old Aug 3, 2005 | 05:47 PM
JerrySimm's Avatar
JerrySimm
12 Gauge may be more satisfying. Especially if you have a pump to get that feel of racking one in the chamber first. Just Kidding
Have you checked the connection at the plug. This sounds like it could be a loose connection. If so, it may be getting hot at the plug as well. Note that there are 3 connectors in the plug, and any one of them can spread out and get loose while the others remain fine. It could also be a problem in the wire, which is going to be a royal pain in the rear to trace down. You don't mention the year or the model. That could have some bearing on the situation as well. If it's not the plug, 1st step is to find a wiring diagram and see what you're dealing with.
Old Aug 3, 2005 | 09:57 PM
K2JJB's Avatar
K2JJB
what year and model,? some of us have the wiring diagrams and might be able to provide more clues if you tell us what year it is.
Old Aug 4, 2005 | 07:04 AM
Brown Beast
1995 4X4 EDDIE BAUER, 4.0 V-6, AUTO TRANS, 15X,XXX mi. I checked the plug with a volt meter. one wire must be the ground wire, becaus i had no voltage to 2 of the 3 wires. Removed the battery & traced the harness back to the fire wall (kinda, those wires go evreywhere! ) did not see any obvious damage, and most of the wires are in the plastic shield or wrap that they put the harness in from the factory.
Old Aug 4, 2005 | 07:32 PM
JerrySimm's Avatar
JerrySimm
When you checked the plug, did you check the female blade connectors inside to see if they formed a tight fit on the male blades on the bulb? I have seen one of these spread open and loosen up. It looks like the Red/Black wire is the low beam power supply and the black wire is the ground. It looks like the wiring junction should be near the passenger side headlight, so if only one side is giving trouble, the problem is probably nearby. Here is the wiring diagram from the autozone site
Old Aug 4, 2005 | 08:34 PM
dogman's Avatar
dogman
Brown Beast, It sounds like you have a split in the wire in the harness or and I don't know if your truck has it a multi-switch up on the steering column. It will do the samething. I'm rewiring a ford contour becouse I'm sick of all the shorts.
Old Aug 4, 2005 | 08:53 PM
dogman's Avatar
dogman
Thumbs up
I was thinking, You need to go see Mil1ion site and then go to North Of The 49th then to Head For The Repair Shop look for Headlight Re-wiring Mil1ion has some really good stuff in there.
Old Aug 5, 2005 | 04:05 AM
95limited's Avatar
95limited
I had the same problem with my 95 Limited. My problem was caused by a cold solder joint on the Lamp Out Warning Module. The plastic piece that is around the Message Center pops right off and the LOM is located under and slightly to the right. If it's like mine, you can move the wires around and the head light will go on and off. You can also short between terminals 1 (W/LG) and 11 (DB/W) on the LOM to see if is causing the problem. I pulled mine to replace it and decided to have a look inside. I resoldered a cold solder joint I found and it has worked fine for the last two years.
Old Aug 5, 2005 | 05:26 PM
Brown Beast
Thanks!
Thanks to all that replied, And thank you Jerry for the wire diagram! Thats cool. I cut the wires BEHIND the bulb connector, and shure enough, had power. So I cut off the factory conector and used heavy duty connectors off from AGCO farm tractor parts bin. All is well. ( So far ) Now I have a " may pop" tire, and since no one knows of a lift kit for this truck, I priced a new set of 265/75/16 standard load mud terrain tires today. Shure wish I could get those 285/75/16's under there! <-ya !
toohott7718
General Automotive Discussion
Mar 3, 2015 09:47 PM
popeye47
Jul 31, 2012 07:13 AM
Ziegelsteinfaust
Apr 13, 2011 10:27 PM
dtodd
Feb 14, 2011 08:45 PM
Rattler60
Sep 30, 2010 10:16 PM
