1988 E150 relocations (battery/intake)
Old Aug 1, 2005 | 12:07 PM
dgeist's Avatar
dgeist
Greetings. I'd like to try and relocate some items in the engine bay of my 1988 e150 (5.0 EFI) and was hoping for some suggestions from those who have tried/done so already.
1) The factory airbox is convoluted and in the way whenever I try to work on anything. I considered retro-fitting a K&N system from an f150, but it seems like the plumbing coming off the brake master cylinder would be in the way of the air tube routing. I've also considered fabricating a short-ram to reside just in front of the factory AC system. If that's the case, then:
2) The battery would need to move over on top of the dirver's-side fenderwell. It appears to have bolt holes for some kind of kit to be fitted but haven't ever seen these kits in person or photos.
Ultimately, I want to get a clear shot at the top of the engine without dismantling it every time. What have you folks done?
Dan
Old Aug 2, 2005 | 06:07 AM
Ian F's Avatar
Ian F
There is a battery tray and hold down assembly available for the driver's side. It's meant for a dual battery set-up and is available new from your local Ford dealer (I called and asked a year or so ago) or do some yard searching for a used one.
The factory EFI air intake assembly is definitely a pain to work around. The problem I see with removing is most aftermarket ones just add a cone-filter which sucks in hot air from the engine bay whereas the factory set-up is a true cold-air-intake (CAI). To make an aftermarket CAI work in a van will require some creative plumbing and may reduce some of the intended idea of improved access.
Good luck and post pics if you are able to make the F-150 intake work.
Supercab
13
Mar 4, 2013 06:47 AM
Gibby55
Aug 29, 2012 12:41 PM
Ditchpig_01
Dec 22, 2010 08:40 AM
Monty06
Bronco II
Jul 2, 2005 10:00 PM
DaParm
1997 - 2003 F150
Sep 11, 2004 08:52 PM
