I will like to say hi to all. I'm new thank you. I just rebuilt my 302 ford from the top to the bottom of the motor. And spend a lot of money can't get the boat to pass 2100 rpm's. call tyhe engine guys they came out and said it was the timming so they took the disturburator and they curve it . still cant pass 2100 rpm. so i change a the gas in the boat new holly cab. everthing new still no luck. please help thank you.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Moved and member notifed
