Flame Thrower Kit + Cats?????
Old Jul 30, 2005 | 11:03 PM
351M's Avatar
351M
All Jegs part #'s and prices.
Fuel pump, Accel: 310-74701 $159.99
Nos Fan Spray Nozzle, Brass (requires jets) Part No:741-13503 Price $ $14.99
Heres the link to the jets:
http://www.jegs.com/cgi-bin/ncommerc...72&prmenbr=361
Fuel Sol. Part #: 741-16050 Price: $64.99
Link to the lines an fittings:
http://www.jegs.com/cgi-bin/ncommerc...cgrfnbr=153829
Ignition Coil: 555-40105 Price $$16.99
Condensor: 110-100108 Price: $9.99
Relay x2: 121-8961 (1 for the fuel pump and one for the Coil) Price: $26.99 (cheaper elsewere like autozone.
Toggle Switch: 251-5582 Price:$7.99 (the trigger wire from each relay wires to this switch, it can get power from the fuse box)
The things like signal flashers like a Tridon 12 lamp unit can be had at autozone, as can the wire, and pretty much anything else I listed above. In other posts.
At least this way you have an Idea of the price and what the parts are. Another cheap way to get the pumps and NOS parts are through ebay.
Old Jul 31, 2005 | 12:01 PM
F-150RedBeast's Avatar
F-150RedBeast
ok thanks a lot 351... i may start getting things and checking this out...
i think i am going to put a separate tank somewhere, like you said...where are you planning on putting it though???
ight i will check back in with ya and might have a question or two, or just to let ya know how its going....thanks again for all your help
Old Jul 31, 2005 | 12:59 PM
351M's Avatar
351M
Well, my truck has no tanks under it, my propane tank is in the box so i'm probly going to put a rear tank in and run it off that. A small marine tank in the box would do fine though, it has a quick disconnect so you can remove it if you need the space etc. BTW the jets look to start at 14 thou. So there is your starting point. Start small and work up. See what you can find for a parts place that seels the jets locally, it beats having to order from jegs all the time. Pretty much all the supplies can be found locally anyway but it wasx easier for me to point you to jegs and thier part #s so you knew what I was talking about.
Old Jul 31, 2005 | 08:49 PM
F-150RedBeast
alright, again thanks a lot, i will see what i can come up with...might come back and have some questions for ya later
thanks again
74F100LGM
23
Jul 31, 2019 01:45 PM
Mister_King
Jan 11, 2015 10:03 PM
darren_palms
Dec 21, 2014 04:56 PM
Tomfo23
Sep 23, 2014 06:16 PM
BIG-BAD-794X4
71
Aug 15, 2007 03:01 AM
