If I go this route, will I need to replace the pink resistor wire with a non-resistor wire? Or will the coil function well with the current (i.e. stock with standard points ignition) wiring?
From what I've gathered, the Ignitor II/III require a true 12v, which my truck with a resistor wire will not give. The Ignitor I works with <12v. To get 12v you'd need to run a new wire from the ignition switch (i.e. bypassing the pink resistor wire with a non-resistor wire).
Pertronix sells a relay which allows you to use the resistor wire to control a true 12v from the battery or another source: Ignition Power Relay
A bit pricey though for a relay + wire. I'm debating if I'm going to gain anything bypassing the resistor wire with a mostly stock 302 with Ignitor HEI + Pertronix coil.
Truthfully? I tend to put my trust in the people that use the stuff, rather than those that watched a training video.
I'm not passing judgement on Pertronix as I have 0 reason to doubt their capabilities - however, it means more to me if someone on this forum said "I've run the coil both ways (with and without the resistor wire) and did not detect an appreciable difference"
I may not get that answer, but isn't that what these forums are for?
What the deal is, a Flamethrower coil for example, already has 1.5 ohms resistance, it's not necessary nor desirable to keep the "pink wire" in the loop. Seems to me everytime I read about problems, people are not deleting the pink wire, and/or have poor grounds and connections. Both the Ignitor and the Flamethrower seem to like full battery output juice. Open up the spark plug gap to about .045 to take advantage of the increased secondary voltage. Everything in the ignition system needs to be in good shape to avoid arcing, though - cap and wires, clean, tight grounds and connections. Remember this arrangement increases voltage from around 20k to 45k volts. Use heavy gauge (not "bell wire") wire to replace the pink wire.
Pick up a tube of Permatex dialectric grease and stuff the boots at the spark plugs, dist. cap and coil. You should notice improved starting, smoother idle and better all around driveabilty with this setup.
Makes me wonder if I should bypass my pinky How exactly does the wire attach at the switch?
On my 64 there is a bayonet lug connector. It's been a while but iirc the modern replacements are smaller and won't fit... so I just soldered the new wire on.The underdash contortions required - not my favorite on these things, get in and get out.
Btw, have also heard some people say that the Pertronix doesn't play well with the old generator systems. Something about "dirty power" or somesuch. Have not had any trouble at all with the stock 30 amp setup for several thousands of miles, offroad, highway, mountains and deserts, brutal Midwest winter, etc. Works for me anyway.
The pink resistor wire itself doesn't connect to the ignition switch. Under the dash, in the main wiring harness, the resistor wire is spliced into a conventional wire.
In the picture the pink wire goes into a rubber covered splice joint and comes out as a red w/ yellow trace conventional copper wire.
So in the case of these pictures,to by pass the pink resistor wire,you would splice into the red w/ yellow wire and run it to the + side of the coil!
Yes, but you don't have to go all the way to the coil.
The resistor wire doesn't go all the way to the coil. The wiring harness that goes to the coil plugs into the main harness at the firewall. The resistor wire ends at the plug.
The Pertronix module itself requires a full hot-in-RUN and START. This is not available under the hood on Fords and must be taken upstream of the ballast resistor. The RED with YELLOW stripe wire you find is appropriate for the module, which unlike the coil, draws very little current. It is upstream of the ballast resistor and also services the dash lights.
To use, or not to use, the ballast resistor depends on the coil. The stock coil, and some applications of various Flame Thrower coils require the ballast resistor. The Pertronix documentation specifies whether or not to use the ballast resistor (even on the box I believe). Note that this is independent of what the Pertronix module itself requires, however, maybe you're not asking about the module.
If it doesn't go all the way to coil then where does it end up once its spliced into the red w/yellow wire?where does it end up at?
