Flame Thrower
Old Jan 14, 2006 | 06:20 PM
BIG-BAD-794X4's Avatar
BIG-BAD-794X4
Flame Thrower
What Do You Guys Think Of The Flame Thrower Kits?
I Have Been Thinking Of Getting One For My Truck
But Wanted Some Info First, Like How Well They Work,
Pros/cons, Other Kits, Or How I Could Make My Owne.
Old Jan 14, 2006 | 06:21 PM
ford390gashog's Avatar
ford390gashog
are you talking about ignition systems? or flames out the pipes?
Old Jan 14, 2006 | 06:23 PM
BIG-BAD-794X4
Sorry!
Out The Pipes.
Old Jan 14, 2006 | 06:25 PM
ford390gashog
you just need a coil a primary wire a spark plug a bung and a switch and run the engine rich or add a fuel dump inline.
Old Jan 14, 2006 | 08:14 PM
76 F-150 390FE's Avatar
76 F-150 390FE
coulent you also inject propane into the pipes as a fuel source?
Old Jan 14, 2006 | 08:32 PM
brown79's Avatar
brown79
sure propane would be better as it would save you from having to run raw fuel through your engine.
Old Jan 14, 2006 | 09:28 PM
Mil1ion's Avatar
Mil1ion
This is actually a General auto topic not a 73-79 truck topic.
The guy on TV with the hot rod shop just had a show about creating them.
Just so you know .......They are HIGHLY ILLEGAL in every state and province.
Old Jan 14, 2006 | 09:57 PM
BIG-BAD-794X4
The rig I am puting it on IS HIGHLY ILLEGAL any way so I am not to worried about that.
Old Jan 14, 2006 | 11:05 PM
ford390gashog
propane works too.
Old Jan 15, 2006 | 01:17 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
If you going to use gas which is hard on the motor make sure you don't have Cats. I would go with Propane and use a VW camper van tank, it's 6 1/2" x 23" long easy to hide inside the frame. Make buzzers out of a common relays to fire your coils if dual exhaust or build a timer to flip flop a relay for alternate left right left right. Check the net under flame throwers for ideas but you can build your own cheaper. Why be normal?
.....o&o>.....
Old Jan 15, 2006 | 06:28 AM
74 F100 351m's Avatar
74 F100 351m
stacy did it on Trucks TV show that is were I would start looking.
Old Jan 15, 2006 | 12:38 PM
ivanribic's Avatar
ivanribic
FWIW the Auto-Loc and most other brands that cut spark to cylinders WILL make a flame but it's very hard on your engine. You're washing the oil off the cylinder walls with raw fuel. I'm piecing together my flame throwers but I probably won't have them done for another month or so. I will be using a seperate fuel nozzle in each pipe to fuel the flame so that I don't have to destroy my engine to put on a flame show.
In regards to legality, there's a lot of stuff that's not legal to USE on the street, but this doesn't mean you can't have it on a street driven vehicle. It's really no different than offroad lights. Just don't turn them on when you're on the street and there will be no issues. Besides, unless you light them up nobody would ever know you've got flame throwers.
I'll put together an article with details on how I build mine if you can wait a little while.
Old Jan 15, 2006 | 12:56 PM
Mil1ion's Avatar
Mil1ion
My comments were only intended to let a person know that this is a great way for a person to bring attention to oneself and if one considers it worth it or not to be confronting a peace officer.
Some people in this world aren't rebels to the law.
Old Jan 15, 2006 | 03:50 PM
"Beemer Nut"
On the show Trucks Stacy did a crappy install for the plugs, they should have bungs welded in at the top so everythings out of sight from the side and rear view. Far as the law, rules or laws should be bent at times unless your a walking corpse of a person, not me.
.....=o&o>.....
Old Jan 18, 2006 | 01:32 PM
countryF150's Avatar
countryF150
ivan, great idea on the article after your done, i think there's quite a few of us interested.
country
