turbo surging
Old Jul 27, 2005 | 04:53 PM
kenzmad's Avatar
kenzmad
turbo surging
when I am hauling my camper and boat pulling a hill I hear this sound. kind of like pressure being let off in rapid bursts. my search of this site has led me to believe that this is not good. Ive got a 99 350 with the banks chip, exhaust and trans controller. is this problem correctable with the wicked wheel?
kenzmad
Old Jul 27, 2005 | 05:25 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
sounds like your fan clutch engaging. Is it a roaring sound? If it is this is what it might be
Old Jul 27, 2005 | 05:33 PM
curtwalk's Avatar
curtwalk
I had same problem after chip, cold air ind. and 4" exhaust. Made loud swooshing noise when let off after hard acceleration or if accelerate after 65-70 mph with heavy trailer. It was turbo surge and the wicked wheel completely cured it. It sound like a mini jet under load. It works great.
Old Jul 27, 2005 | 08:07 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
kenzmad
I agree with your diagnosis, and yes, the wheel will fix it.
Do you have a boost gauge? That will tell you how urgent fixing it is.
Old Jul 27, 2005 | 08:19 PM
HeatStroked's Avatar
HeatStroked
Wicked Wheel will fix it, so will the ATS vented compressor housing.
The wheel is a cheap fix but requires lots of labor if you do it off the truck. The housing is expensive but can be installed on the truck and is a fairly easy installation compared to the off truck Wheel intall.
Old Jul 27, 2005 | 08:39 PM
alan hodges's Avatar
alan hodges
I installed a ATS turbo housing has a 4" inlet . This took care of all the flutter . My truck has a 4" exh, chip, K&N cold air . I think this will help you.
Old Jul 27, 2005 | 11:27 PM
Kwikkordead's Avatar
Kwikkordead
I concur on the Wicked Wheel. Your symtoms exactly match mine and the new wheel completly cured it. The intake sound went from sounding like Darth Vador suffocating to a nice strong turbo whistle/whine.
Old Jul 28, 2005 | 09:04 AM
kenzmad's Avatar
kenzmad
thanks guys, anyone have any suggestions on where to purchase the wicked wheel.
kenzmad
Old Jul 28, 2005 | 09:28 AM
Kwikkordead
I don't know why none of this site's sponsors carry one, I would post a link!
I bought mine from www.dieselinnovations.com. They call it the "swisher wheel". Or you can do an Ebay search for "wicked wheel". Bankspower.com also has it under another name. They're all the same thing, just different branding. Pick one that makes you happy and buy it.
You'll have to copy and paste that link above or you'll end up at Motorhaven.
Old Jul 28, 2005 | 10:04 AM
curtwalk's Avatar
curtwalk
I bought mine at dieselsite.com for $70.00. The swisher wheel at dieselinnovations is the same thing, different name I think. I believe is around $80.00
Old Jul 28, 2005 | 11:04 AM
SoCalDieselFan's Avatar
SoCalDieselFan
Are these wheels different sizes - depending on the saize of of your turbo / housing? or is it a one size fits all proposition. Forget who it was now ... but there's larger than stock turbo options and this guy had one. 80 vs. 88 or something like that. So my question is - would the larger turbo w/ bigger diam breathing tubes - also cure the surge issue?
Id prefer to get the bigger housing and compressor wheel - and the wheel be a wicked/swisher/banks wheel.
Old Jul 28, 2005 | 10:59 PM
Kwikkordead
All the "wicked wheels" are 80mm. If you want to get a bigger wheel, then you have to buy the turbo that comes with it. And that's a good thing, just a lot more $$$. EGT's go way down, flutter goes away, bragging rights are improved. The housing tolerances are so close that you can't get a credit card in between the wheel and the housing.
kenzmad
Sep 20, 2006 12:39 AM
kenzmad
Oct 31, 2005 07:05 AM
kenzmad
24
Oct 8, 2005 05:56 AM
kenzmad
13
Apr 2, 2005 06:40 AM
billb
Nov 1, 2002 01:56 PM
