Testing Coolant Additive
Old Jul 27, 2005 | 12:01 AM
BGFNRED's Avatar
BGFNRED
How do you go about checking the coolant additive. I just changed out the coolant and hoses on my 88 F250 7.3L and used the Ford additive using the reccommended amount per gallon of coolant (I think it was 4oz. per gallon) but what do I use to check this mixture?
Jason
Old Jul 27, 2005 | 12:08 PM
deanj's Avatar
deanj
Go to NAPA or your IH dealer and ask for the PH test strips. All the info is on the package. You could try FixOr Repair Daily but they will probably look at you like you have 2 heads.
Old Jul 28, 2005 | 03:04 PM
smashing4455's Avatar
smashing4455
I would check that coolant (SCA) very quickly if i was you. All the threads I have seen on this site from the posting guru's show 2 bottles of the SCA for the entire system on a 7.3. If this is true you have overcharged your system by alot and if you look at this site you will find that is just as bad as not doing it at all.
http://www.filtercouncil.org/techdat.../faqhdcool.htm
http://www.filtercouncil.org/techdata/tsbs/88-1R2.pdf
You might also want to try this instead of having to deal with the level monitoring.
http://www.shell-lubricants.com/prod...=12&bgcolor=&1
Old Jul 28, 2005 | 03:08 PM
smashing4455
I did notice that the first link said to use 4 ounces per gallon but I think David Spon. a posting guru has said he tests at 2 bottles with 3 gallons of ford brand VCA 7 coolant and Three gallons of distilled.
Old Jul 31, 2005 | 03:50 PM
bluthunder's Avatar
bluthunder
caterpillar sells a coolant with the additives already in. no need to monitor sca levels
Old Feb 6, 2006 | 10:30 PM
F350_Hauler's Avatar
F350_Hauler
Smile How much DCA4?
Am I reading this right? 3 gallons of low-silicate anti-freeze, 3 gallons of distilled water and two bottles of DCA4 (16 fluid ounces each X 2 = 32 ounces) for entire system flush and renewing of fluids.
Old Feb 7, 2006 | 06:08 AM
deanj's Avatar
deanj
Ford 7.3 has 29 qts (inc 5 in overflow). 1. drain and flush. 2 mix 50/50 with a low silicate AF and distilled water. 3. Add 2 pints of sca FW-15 . Cat, rotella and fleet guard are 300k test free AF, they are pretty much flush and fill - do not add any water. Personally whatever you use test the ph and nitrite levels regularly.
Old Feb 7, 2006 | 07:26 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Sounds about right. 32 quart capacity in my PSD...takes three pints of SCA to get it right on the test strip.
RM2738
6.4L Power Stroke Diesel
Aug 9, 2012 03:19 PM
Tom
6.7L Power Stroke Diesel
Mar 6, 2011 08:08 PM
JReinert
17
Sep 10, 2010 11:39 AM
afinepoint
Aug 11, 2004 08:02 AM
jakedog
Mar 30, 2002 11:02 AM
