6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Coolant additive question...
Old Aug 9, 2012 | 07:47 AM
RM2738's Avatar
RM2738
I'm at the dealer right now... Nitrates are low, their adding the Motorcraft coolant additive... Question is: how much additive? Tech says 4 oz per gallon of coolant, so on a 6.4, it's 50/50 mix, 4 gallon capacity, so 8 oz? Bottle says 4 oz per gallon of system capacity... But it also says "unless engine specs call out differently." do these engines require a different amount of additive?
Thanks
Old Aug 9, 2012 | 08:22 AM
ljutic ss's Avatar
ljutic ss
This is the formula depending on nitrite level.
1 pint/per 4 gallon 0-200 nitrite level
2 pints/per 20 gallon 500 nitrite level
1 pint/per 20 gallon 800 nitrite level
the ideal nitrite level is 1200
when nitrite level reaches 4000 it's time to flush cooling system.
Old Aug 9, 2012 | 10:53 AM
ssharber's Avatar
ssharber
The 6.4's hold 30.6 gallons of coolant. Is he saying 4oz of additive for each gallon of coolant or each gallon of 50/50 mix coolant. Big difference in an engine with a capacity of over 7.5 gallons.
Old Aug 9, 2012 | 10:59 AM
RM2738's Avatar
RM2738
The engine coolant capacity is only 24L... Plus radiator capacity is Probobly around 30L? Not gallons?
Old Aug 9, 2012 | 02:00 PM
ljutic ss's Avatar
ljutic ss
The cooling system on a 6.4 is 30.6 quarts or 29 liters.
Old Aug 9, 2012 | 02:29 PM
RM2738's Avatar
RM2738
So I really 32 oz of additive based on bottle instructions.
Old Aug 9, 2012 | 03:19 PM
ljutic ss's Avatar
ljutic ss
Actually it's what the test strip shows in nitrite levels that will determine as far as adding or flushing.
Resendiz
41
Oct 21, 2016 12:46 AM
BuckHammer
22
Feb 29, 2012 05:39 PM
north2south006
Feb 7, 2011 11:39 AM
Benchwrench
Sep 7, 2010 01:33 PM
whattatruck250
Jun 27, 2010 06:10 PM
