Double clutching a top loader 4 speed....
I tried to post in the tranny section but it kept saying I wasn't logged in.....
I have a top loader 4 speed moving with my 390 and ever since I got the truck I haven't been able to downshift from 3rd to 2nd. I thought it was clutch issues because there wasn't any clutch left, but I've installed a new clutch and it still won't shift. I was told to try double-clutching. It works, I can kick it out of third, rev her, and push the clutch and shift to 2nd. I was just wondering if anyone else has the same problem? Is this common with these? Anything I can do to make it smooth?
I was told back in the '70's by a Ford mech and fellow racer that if the toploader won't down shift, Adjust the clutch, then adjust the clutch, and then adjust the clutch; then change the syncros in the tranny. That's the only two things that can cause it. The trannies are pretty much bullet proof. Mine was the clutch slightly dragging the first time in my race car. The second time it was syncros.
Hmmm.....looks like I'll be adjusting the clutch..LOL
The clutch is brand new, maybe 25 miles. Any chance it'll adjust and break-in and the shifting will be smooth?
And by adjusting the clutch I'm ***-u-me-ing you mean the rod that pushes the fork right? I don't think there is anything else to adjust....is there?
Sounds like someone ground the heck out of 2nd gear since the clutch was gone.
Rebuilding one of these tranny's is pretty simple. Done with basic hand tools, but takes some finesse if you never had one apart.
If your clutch is adjusted fine for normal driving...then adjusting it more for downshifting is NOT going to help. If it upshifts fine, then let it go. The ol 4 spd just needs fixed.
Larry is it a good book out there to read up on rebuilding thse things.
I have that t-18 and the other out of the 427 glaxie. I would like to rebuild the t-18 first and then pull the car trans and rebuild that one.
I have never had a tranny apart before and would like something to read first
Thanks
-Brandon-
Thanks
-Brandon-
As for tranny rebuilding...........not really sure there is a "new" book printed on this. Most likely an old Motors manual or such. Maybe find a FOMOCO book on them..
I learned by doing....it took a while, but now I do them in my sleep...LOL!!
They list special tool # for certain bearing removals....never done it. Simple hammer/block of wood and have never had issues yet. There are certain things that rely on the "Monkey/football" principle...LOL!!...but for the most part they are simple.
I can strip one in probably 20 minutes.....After cleaning parts, it's another 30 minutes to have it back in one piece. There is a sequence though...and you have to do it or things don't go back together.
A good start would be David Kee Toploaders(in texas). Great guy, got to know him from another forum. You can get a complete rebuild kit for around $150 for these. All small pieces, synchros, bearings...etc. He carries/makes everything, including cases, tailhousing, gears, shafts. His site is davidkeetoploaders.com. I'm sure he would have the tear down instructions. We've met a couple times at Ford swap meet in Columbus, Ohio...he even bought me dinner once . Give him a shout.
Eventually I'll be rebuilding the motor as well as upgrading, higher comp. ratio, cam, port polish, etc....but for now, just the tranny...and that will still probably be another 6 months....haha....I just bought a house so that will take up all my time until I can get back in the garage
I checked out David Kee's site when I was trying to ID my parts, I must say it was very well put together and has tons of info I found useful! Although after the I.D. it appears I have a 69 428 Fairlane gearhousing mated to a 69 390 Torino tailhousing with a small input shaft and 28 splines out the back!!!
No wonder I want to rebuild the engine too, who knows what the prev. owner did!
Can I ask this, just because I'm a little green on the shifters... Are you sure it's a "top loader" or is it the standard truck T-18 that has the shift mounted to the top of the case? In my dark corners of the memory cabinet, these two are completely different trannys. Larry can shed some light for us
--Mike
--Mike
--Mike
--Mike
I'm guessing mine probably weights about 75lbs. I'm pretty sure it's not aluminum either, what year car is your tranny out of Brandon? Did you get a chance to I.D. it on David Kee's site? I certainly wouldn't mind having a lighter tranny, although on a 5k# truck I guess it won't matter much! LOL
