86 Ranger dash removal
Old Jul 22, 2005 | 08:33 PM
t_dickie's Avatar
t_dickie
I need help guys. I'm trying to get the dash (plastic around guages, not the whole dashboard) out, and can't figure out where the screws are at the bottom, if there are any. If anyone knows how to get to them, or any tricks to get it out, please let me know ASAP.
Thanks,
Trevor
Old Jul 24, 2005 | 04:22 PM
TigerDan's Avatar
TigerDan
Here's a pic, it shows the screw locations pretty clearly. The bottom four are under the lower trim pieces, and the top four should be visible by getting down low and looking up under the edge of the dash overhang.
https://www.ford-trucks.com/user_gal...=83581&width=2
-TD
Old Jul 25, 2005 | 05:10 AM
tomw's Avatar
tomw
IN cas you need to know how to remove the trim pieces, you will have to pull them off. They each have to metal spring fasteners that poke into holes in the metal of the dash and guide posts. The leftmost has the headlight switch ****, and it must be pulled out of the switchbefore you remove the trim. You have to reach up under the dash, and find the button on the side (drivers, i think) of the switch, and depress the button while pulling the **** out at the same time. Put it back in gently to turn the headlights off..
It can be re-installed by pushing it in until it 'clicks'
tom
Trevor.801
Dec 22, 2014 09:43 PM
Trevor.801
Dec 13, 2014 12:57 PM
Trevor.801
Jun 19, 2014 10:52 AM
Trevor.801
Jun 1, 2014 08:50 PM
