OHHHHH....Those flaps They were already mounted when I made the deal,it was a option that I had to have.Only problem is that I get a lot of people tailgating me.
thanks fryhog for posting pics. did you use any brackets. my instructions
use a metal plate behind flap and liner so it may be different than your
setup.
ill hold back on the teasing
They did give me the metal brackets when I got the flaps.The brackets were made to mount the flaps off the frame rails,but that did not apply to my truck?????There was no way that I could see coming off the frame,the height did not match up,and the leaf springs would be in the way of the bracket....so I did not use them.Your set up may be a better application then what I had,let me know how it works out for ya.
