Sponsored by: Real Truck
Grill Insert
Old Aug 5, 2005 | 11:14 AM
fyrhog's Avatar
fyrhog
Grill Insert
Im installing a 6 piece grill insert on my 06 SD.The 4 horizontal pieces I could get the access I needed to attach the mounting harware.How can I access the space to mount the hardware for the 2 end verticle pieces?Do I need to pull the headlight or is there another way to do this.
THANKS GUYS
Old Aug 5, 2005 | 12:49 PM
BFR250SD's Avatar
BFR250SD
Can't you just pull the grill off, like on the 99-04's. The 4 little screws that hold it on on top of the grill.
Old Aug 5, 2005 | 12:52 PM
fyrhog's Avatar
fyrhog
OK I will go take a look and see........Thank You
Old Aug 5, 2005 | 02:42 PM
1BDTrk's Avatar
1BDTrk
and the 4 clips on the bottom.. just like the 05's I bet.
Old Aug 5, 2005 | 08:32 PM
fyrhog's Avatar
fyrhog
I got it guys,,,,thank you much.Theres screws at the top of the grill that let you access the backside,they were right there in front of me....
Thanks Guys
Old Aug 5, 2005 | 09:53 PM
showin4fun's Avatar
showin4fun
Is the 2005 F350 grille the same physical dimensions as the 2004 F350? I would like to put a Billet Grille on my truck but I like the looks of the three piece kit compared to the six piece kit.
Later.....
Old Aug 5, 2005 | 10:28 PM
Bear Hunter's Avatar
Bear Hunter
Your probably going to need to pry up on the spring loaded tabs on the bottom after you take the screws off the top. I use a computer mouse pad on my bumper and a flat pry bar to work them out.
Old Aug 5, 2005 | 11:44 PM
BFR250SD's Avatar
BFR250SD
Good deal brother. Post some pics.
Old Aug 6, 2005 | 12:12 AM
BFR250SD's Avatar
BFR250SD
Bear,
Where did you get your inserts from? Those are sharp, I might just bite off of ya.
Old Aug 6, 2005 | 12:17 AM
fyrhog's Avatar
fyrhog
Tomorrow I will get a pic into my gallery for you guys.
Old Aug 6, 2005 | 01:16 AM
Bear Hunter
BFR,
There just Street Scene inserts that I painted and cleared to match my factory color code.
Old Aug 6, 2005 | 07:07 AM
BFR250SD's Avatar
BFR250SD
They look sharp man.
Old Aug 6, 2005 | 01:39 PM
fyrhog's Avatar
fyrhog
I drop a pic into my gallery of the grill insert,it is made by Precission.Let me know if you guys want more info on it.
Ron
Old Aug 6, 2005 | 02:51 PM
captchas's Avatar
captchas
Guest
good looking truck man. and better looking side kick. the grill looks more like it should be right from ford
Old Aug 6, 2005 | 03:13 PM
fyrhog's Avatar
fyrhog
Yep...it is from ford.Thats the grill they use in the chrome package,but you can get it if you dont get the chrome package option.Now that other package would even make a Dodge look good..LOL
