Wiring problem
Old Dec 7, 2002 | 08:00 PM
REDNECK302's Avatar
REDNECK302
Wiring problem
Code Blue
The heartbeat just stopped.
I have a wiring problem on my 78 F150.
I have replaced the alternator and the voltage regulator and im still not getting a charge and my brake lights dont work when the lights are on but when they are off they usually work. HELP!!!!!!!!
1978 FORD F150 4X4
Old Dec 7, 2002 | 08:27 PM
Mike W's Avatar
Mike W
Wiring problem
Try connecting +12 to the S terminal on the voltage regulator. This will tell the regulator to supply voltage to the field terminal of the alternator. The alternator will not produce an output if the field does not have voltage on it.
Old Dec 7, 2002 | 11:11 PM
macguyver's Avatar
macguyver
Wiring problem
Sounds like a chassis ground problem.
Greg
'77 F-250 Camper Special 400ci driver
'76 F-250 Supercab 360ci current project
'71 Mach I 429CJ in storage
'79 F-150 for parts
huct on foniks wurkt fer me
Old Dec 7, 2002 | 11:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
Wiring problem
The lights are definitely a chassis ground problem. Fix that first and it may fix the alternator. The regulator is grounded to the fender.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Dec 8, 2002 | 06:49 AM
theonlybull's Avatar
theonlybull
Wiring problem
Jasonf150
Nov 8, 2014 11:51 PM
brokersteve
Oct 9, 2012 12:21 PM
munk420
Nov 21, 2008 09:45 PM
chmath
Electrical Systems/Wiring
Mar 11, 2005 10:41 PM
coolmint94
Aug 18, 2003 11:16 PM
