help needed with trailer wiring problem
Old Jan 24, 2005 | 06:06 PM
chmath's Avatar
chmath
Exclamation help needed with trailer wiring problem
I have a brand new trailer with a four wire flat plug....All of the lights work fine when hooked up to my wife's truck ..The problem is when I hook it up to my 1990 F150 all of the lights work but when I turn on the Blinkers they dim and blink fast....I have checked all wiring but still have no clue what the problem is....
Please help.....Thanks in advance
Old Jan 24, 2005 | 07:13 PM
wagntwister's Avatar
wagntwister
Bad ground.
Old Jan 24, 2005 | 08:00 PM
Franklin2's Avatar
Franklin2
I think you may need to change your flasher to a heavy duty type. Then try it.
Old Jan 25, 2005 | 02:22 PM
chmath's Avatar
chmath
Smile Found the problem.....It was the relay......
Thanks everyone ....The problem was the relay wasn't able to run both the truck and trailer....Bought a heavy duty relay and it solved the problem...
Thanks again....
Old Mar 10, 2005 | 10:07 AM
JustLearnin88's Avatar
JustLearnin88
Trying to solve my own problem with the search feature - found this old thread.
Anyone know where can I find one of these relays please!??
JL:88
Old Mar 10, 2005 | 10:28 AM
chmath's Avatar
chmath
You can get them from any auto parts store like AutoZone Napa ....They cost around $6.00...
Old Mar 10, 2005 | 10:37 PM
Franklin2's Avatar
Franklin2
I always thought they were called a "flasher". You go in and try to buy a turnsignal relay, they may give you the wrong thing.
Old Mar 11, 2005 | 10:41 PM
JustLearnin88
Replaced the "Hazard Warning Flasher" found in the fuse box of my '88 F250 with a 'Heavy Duty' "LOUD" Flasher.
Doesnt seem to be any louder than the other one - though it is a bit taller.
WORKS LIKE A CHARM.
Trailer flashers and truck flasher work GREAT now.
Thanks Search Feature / Chiltons Manual & the guys here at FTE - tee hee
JL:88
mitsudave
1997 - 2003 F150
13
Oct 24, 2012 06:27 PM
Aggie05
1983 - 2012 Ranger & B-Series
Aug 17, 2009 03:23 PM
DrFord
All Things Towing
Jan 7, 2009 09:50 AM
BobBarry
Jul 11, 2008 12:08 PM
EarlDale'sFords
2004 - 2008 F150
Mar 19, 2005 07:05 PM
