speaker size
Old Jul 18, 2005 | 08:11 AM
whistling69deuce's Avatar
whistling69deuce
speaker size
i have a 91 f-150 i am using as a beater to save miles on the p-stroker. I have sirius sat. radio and a decent headunit in it for the 1.5 hour ride to work. I blew out one of the speakers in the door. does anyone know what size speaker i can put in the door without too many mods. a little trimming in the door or a few drilled holes i can handle but i don't want to have to like rewire the whole stinking truck. I have heard 4" and also 6.5" fit but just want to make sure before i spend 80 bucks or so on a set of speakers. thanks for the info guys.
Old Jul 18, 2005 | 08:13 AM
EPNCSU2006's Avatar
EPNCSU2006
6.5" goes right in. Only thing I had to do was drill four mounting holes because the stock holes didn't match the speakers I have.
Old Jul 18, 2005 | 02:22 PM
MemOrex's Avatar
MemOrex
6.5" is correct.
Like EPNCSU2006, my holes didnt match with the stock door holes. Only 2 of 4 matched and that was good 'nuff for me , lol
Old Jul 18, 2005 | 02:27 PM
whistling69deuce
thanks for the help guys. once again the forum has come thru. it is so stinkin hard to look that stuff up on the internet. some sites say 4 others say 6.5 you just never know. now. has anyone put speakers in the back?? i have the extended cab. with a fold down bench seat. what would you suggest for rear speaker mounting areas.
Old Jul 18, 2005 | 04:21 PM
EPNCSU2006's Avatar
EPNCSU2006
Extended cab should have 6x8's in the rear already, but I suppose it was optional and your truck might not have that option. If there is no place for rear speakers in the truck, a good alternative would be to get a pair of 6x9 boxes for the rear, and just mount them on the floor.
Old Jul 20, 2005 | 02:44 AM
1993F150XL's Avatar
1993F150XL
If your '91 is like my '93, the stock rear speakers are 6x8. However, most aftermarket 6x8's won't fit an extended cab because the magnet is too deep & bottoms out against the back of the cab. I learned this the hard way. I tried to mount Pioneer 6x8's. I forced the screws in thinking it wouldn't hurt. The next day, I noticed creases visible on the outside of the cab where the magnet had bottomed out. (The truck has since been painted & the creases taken care of.) This is why Crutchfield & most other retailers recommend 5x7's for extended cabs. I just thought I would pass this along to help you avoid the same problem.
Old Jul 20, 2005 | 09:34 AM
JEV's Avatar
JEV
My '91 extended cab doesn't have any rear speaker mounts. I looked high and low for them when I put in my 6.5" in the doors and I found nothing in the rear pillars.
JEV
Old Jul 21, 2005 | 10:06 PM
Kista20's Avatar
Kista20
goto crutchfield.com they have never let me down once. They have a vehicle fitment online where you put in your vehicle and it tells you everything that will work in it.
curtainrod
Aug 11, 2014 03:49 PM
hotrod351
Sep 29, 2011 05:19 AM
bluephi1914
2004 - 2008 F150
Sep 19, 2006 12:40 PM
97rangerguy
Dec 7, 2004 05:17 PM
ksutty
2004 - 2008 F150
16
Jul 17, 2004 11:44 PM
