Door hard to open
Old Dec 12, 2002 | 01:33 PM
sethro's Avatar
sethro
Door hard to open
What should i be looking at if my door handles require some muscle to open the door?
Should i try new handles or is it something internal that is causeing me to you extra force to get the door open?
The doors have a tendency not to shut tight either. the door seals are over 2 years old, i think they have had time to settle. Could this be a factor.
Old Dec 12, 2002 | 02:02 PM
KJKozak2's Avatar
KJKozak2
Door hard to open
It's possible that the door hinges are off a little. Mine was out of allignment after I took it off. First it wouldn't latch at all, then it would latch and stick like yours. Also, check the little plastic sleeve that's on the strike that bolts to the cab. If it's too big, it'll stick. I would probably check the latch itself first. Use a screwdriver as a strike to close the latch and see how hard it is to open. If it works fine, check the other stuff.
Hope this helps.
K.
Old Dec 12, 2002 | 03:19 PM
theonlybull's Avatar
theonlybull
Door hard to open
most likely you hing pins are wore.. but the do could just be out of alignment... open the door, and grab the latch end, can you move it up and down?(the whole door that is) if so it's the hinges.. ford sells the pin/bushings for around 20$ canadian per door. if it's not that then something needs work.. maybe a good lubing, maybe some adjusting.
Old Dec 13, 2002 | 01:39 PM
sethro's Avatar
sethro
Door hard to open
i think the hinges are wore. the door does have some play in it. I will replace them and see if that cures the prob. thanks for the help.
Old Dec 13, 2002 | 03:24 PM
iowacowboy7's Avatar
iowacowboy7
Door hard to open
mdr617
Dec 13, 2010 02:41 PM
jjs2032
Apr 22, 2008 08:27 AM
Chromepro
Aug 29, 2005 06:42 AM
fred white
Mar 24, 2003 08:51 AM
noremac19
Dec 9, 2001 02:33 PM
