Door handle
Old Aug 28, 2005 | 10:42 PM
Chromepro's Avatar
Chromepro
Door handle
I have to pull the drivers interior door handle all the way and give it a little shoulder to open the door. I went in the door today, and it appears that everything is connected correctly, although the interior handle does not appear to pull the latch as far and the exterior, which works fine. Maybe the interior door handle stem is too worn??
Old Aug 29, 2005 | 06:17 AM
jowilker's Avatar
jowilker
cp, I think the lock is working, it is the adjustment of the door itself that is causing the door to stick. Try spraying the latch area with WD40 to start with, and see if there is any improvement.
John
Old Aug 29, 2005 | 06:35 AM
Chromepro's Avatar
Chromepro
I soaked it down, which did give it better movement but no improvement of opening. It is a bit spring on the drivers side door, and previous owner put spacers behind the striker latch. Is hinge adjustment the way to go??
Old Aug 29, 2005 | 06:42 AM
jowilker's Avatar
jowilker
cp, Not being able to see your truck, it is hard to advise. Hinge pins can get worn and cause drag, shims added, etc. If the door unlatches to open then the lock is working. Lift the door and see if there is play in the pin area.
It sounds like a mis alieghment issue, and you will have to play with it until you get it right. IMHO
John
dixiemudder04
WTB - Parts & other
Oct 18, 2012 11:46 AM
jchosler
Feb 28, 2011 01:02 PM
Suber
16
Apr 27, 2008 01:48 AM
wickware
Feb 1, 2008 07:15 PM
code1
Oct 27, 2003 03:30 PM
