Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Welding Question
Old Jul 14, 2005 | 08:23 AM
88F250DIESEL7.3's Avatar
88F250DIESEL7.3
Welding Question
Sirs
I own a 88 F 250
I have a set of Racks, and I want to weld extensions, tie downs ect...
What should I do before I start welding?
Such as disconnectiong both batterys?
I am also assuming to put the ground as close to the weld as possible, so to not make my pickup be a part of the circuit?
Thanks
Clint
Old Jul 14, 2005 | 10:34 AM
cloleson's Avatar
cloleson
I would disconnect the alternator. I have welded on vehicles without disconnecting anything, and not had a problem. I have also fried an alternator. Just my experience.
Old Jul 14, 2005 | 10:37 AM
DetailerDave's Avatar
DetailerDave
I agree with you- disconnect the batteries. Make sure no sparks can get to the batteries, or anything else flammable, for that matter. Connect the ground as close to where you are welding as you reasonably can.
Old Jul 14, 2005 | 02:25 PM
nick88f150's Avatar
nick88f150
Yep, definetly disconnect the battery, that's what I've always been told. Good to go other than that, just watch out for the fuel tank, and lines.
Old Jul 14, 2005 | 11:50 PM
88F250DIESEL7.3
Thanks Cloleson
I did not even think about the Alternator.
Clint
Old Jul 14, 2005 | 11:51 PM
88F250DIESEL7.3
Thanks for the help
Thanks
DetailerDave, and Nick88f150
I sure love this forum.
Clint
Old Jul 15, 2005 | 08:44 PM
rebocardo's Avatar
rebocardo
On my truck using a MIG welder, even with the battery disconnected all the new bulbs in the back where I was working failed within a week of the welding. I thought just bad bulbs until I welded the other side and the new bulbs on that side failed shortly afterwards.
So, now I totally disconnect both battery cables from each battery and pull any bulbs near where I am working. My alternator failed about two months later, but, it was three years after I bought the truck and I have no idea how old it was before that since it was painted Ford blue. But, I do not think it would hurt to pull the alt. plug since it is so easy to reach on a Ford.
Old Jul 16, 2005 | 11:15 AM
coalminer78's Avatar
coalminer78
Also, double check for any leaking gas. You dont need a fire or worse.
Old Jul 18, 2005 | 03:53 PM
jacque_strap's Avatar
jacque_strap
Cover ALL the glass!! Otherwise any sparks that come into contact will cause pitting.
Old Jul 18, 2005 | 06:29 PM
MisterCMK's Avatar
MisterCMK
Better safe than sorry, so disco the battery. I am guilty of leaving them connected on my Mustang when I was welding on the exhaust and never had a problem.
Old Jul 18, 2005 | 07:03 PM
mrxlh's Avatar
mrxlh
Agree with what others have mentioned so far. I would have on standby, a fire extinguisher, or a garden hose already on with a on / off nozzle. Also if welding near a painted body surface, wet rags, to cover the painted surface, and maybe a water bucket with rags to cool off your welds, if welding on the backside of a painted surface, or undercoated surface. (keeps from starting a fire where you cannot see.)
Ryan
Fitzgerald_welding
Oct 5, 2009 01:45 AM
kel1306
Oct 8, 2007 09:30 AM
scouterspokane
Apr 2, 2005 07:02 PM
countryboy75
Exhaust Systems
Oct 14, 2003 04:47 PM
ol74hb
24
Apr 2, 2003 10:02 PM
