I need help with wiring ASAP..
Old Dec 22, 2002 | 01:30 AM
Racerdave's Avatar
Racerdave
I have a 77 F100 and I got the truck and it has a Grant steering wheel on it and the guy that sold me the truck did not hook up the blinkers... I took off the steering wheel and took a look.. I have no idea how to hook them up, and I need some help, I have to drive the truck to my house wich is 3 hrs away.... Tomarrow night... so please reply soon! Very soon!!!! If you could tell me how to hook them up to a toggle switch That would be great for now... I just need to do something to make them temporarily work until I get her home and I can fix them permanently. Thanks ~
Old Dec 22, 2002 | 02:04 AM
masterbeavis's Avatar
masterbeavis
Two words... HAND SIGNALS!!
Left turn, arm straight out
Right turn, arm bent at the elbow, forearm straight up
Stop, arm bent at the elbow, forearm bent straight down
Check the wiring harnass behind the dash and make sure it is hooked up. If it is, there is no easy and fast way to get blinkers. (not that I am aware of anyways) If it is not hooked up, go get a fire extinguisher handy, and plug the harnass in. Check for bare wired hangin round anywhere, and bad connectins(before you plug it in). Also check for bad fuses, and look for a round silver cylinder lookin thing (it's a relay). There should be two of them. Swap them with each other, one does the turn signals, the other does the hazzards. The chances of the relay on the hazzards being good are fairly good in relation to the turn signals. If neither work, take one to the parts house match it up, and get another one. If they still dont work, and you know all the fuses are good, and the wiring harnass is hooked up, take a voltage meter and make sure that all the fusea are getting power. There is soooo much stuff to do and check for when faced with electrical gremlins, hopefully, my suggestions will fix your problem
My .02 cents....
Tony
'77 F250, 4X4 460 transplantee, "Flamer"
'74 F250. 460, "beater" now "1 dead ford"
'73 F250, "midnight auto" now a trailer for the flamer
Old Dec 22, 2002 | 02:09 AM
Torque1st's Avatar
Torque1st
Posting Legend
Remember reading about those in the driver's handbook for your license? :-)
The little round cylinders are flashers, kind of like a relay, but they have a thermal element that heats the contact arm and causes it to make and break contact. If you ask the guys at the parts store for relays they may look at you funny... -hehe
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Dec 22, 2002 | 12:40 PM
Mike W's Avatar
Mike W
Installing the steering wheel should not affect the turn signals. The horn may not work if it wasn't put on right.
Old Dec 22, 2002 | 01:32 PM
Polkat's Avatar
Polkat
Do the emergency signals work? Brake lights? If so, and the underdash connector is hooked up and no wires are broke or cut, it might be the white plastic cam on the turn signal itself. These things wear out (especially the early '70's ones), but are fairly easy to replace if you can solder, and replacements are available at most parts shops (try Napa). I don't like the ones made by HELP as the stiff wire contacts are usually too long, but they can be trimmed to work.
Be advised also that some states (like here in CA) will now ticket you anyway if your turn signals don't work, even if you are using the arm signals out the window!
Old Dec 22, 2002 | 03:46 PM
Racerdave's Avatar
Racerdave
I am not sure if the emergency signals work... havent tryed them... I guess the turn signals worked befor he installed the new Grant stering wheel... So he said... So I duno, what would you recomend if the flashers dont? I am leaving now so I guess I cant get anymore help...thanks I will try some of the things everyone said. Thanks again ~
Old Dec 22, 2002 | 07:45 PM
masterbeavis
Dang, couild you imagine what a PITA to diagnose bad signals past what we have already discussed?? Tracing wires, checking and cleaning connections, renewing grounds.... ugh.....
Tony
Old Dec 22, 2002 | 08:35 PM
masterbeavis
78-13 Ford
Sep 12, 2014 07:45 PM
Max-HB
Jul 31, 2012 04:44 PM
1982_f150
Sep 27, 2008 04:19 PM
FEFordFan
Dec 28, 2005 09:38 AM
