Grant Wheel Horn Button - help!
Old Dec 21, 2005 | 05:22 PM
FEFordFan's Avatar
FEFordFan
My truck had a Grant Steering wheel on it when I bought it. I really like the wheel, but I took it off to replace the turn signal switch and I can't figure out how to get the horn button back on. The spring was taped to the back of the horn button and the other end just looks like it slips onto the end of the threaded steering shaft, but it won't go back on or attach to anything. It was on there really well before and It's driving me crazy because I just can't see any way it could possibly stay in place. Thank you all for your help!
Old Dec 21, 2005 | 06:57 PM
Icicle's Avatar
Icicle
The Grant Instructions that came with the steering wheel when it was new go into detai about the center cap and horn installation. Good Luck. Ours wasnt too bad at all
Old Dec 21, 2005 | 07:52 PM
petes79f150's Avatar
petes79f150
Says here (I haven't installed mine yet) "Position spring on nut.You may find tape a help. Place horn cap in position by aligning dimples on cap with reliefs in fiber material and push until dimples pass fiber. Turn cap left or right until tight (about 1/4"-1/2"). Hope this helps.-P. Merry Christmas
Old Dec 21, 2005 | 07:53 PM
ford390gashog's Avatar
ford390gashog
the above nailed it.
thanks pete
Old Dec 22, 2005 | 01:13 PM
FEFordFan's Avatar
FEFordFan
Thank you guys for your help. The problem is that the spring won't go on the nut. It's not even close - one end (of the spring) is way too big and the other is way too small. I'll try to press the button down over the fiber disc, but I don't know if it'll go. I guess I could try some tape, but it wasn't taped down when I took it off & that seems a little Mickey-Mouse. I guess the person who had it before me had a magical touch with trucks. Let me know if you guys have any more ideas. Thanks again!!
Old Dec 22, 2005 | 01:40 PM
jsutton's Avatar
jsutton
Put the big end of the spring on top of the nut that holds the steering wheel on it should stay by just resting on the threads of the shaft. Then look at the fiber disk that grounds the horn it will have three little notches cut out at like 10 2 and 6 o'clock. The horn button will have three indentions around the edge. Unhook the horn under the hood unless you want it blowing this whole time (irritates the neighbors). Anyway, line the indentions in the button with the notches in the disk and push down and turn. The notches allow the button to catch on the the back of the disk and spring holds it up off the steering wheel so it won't be grounded. But if you want to use the tape just tape the spring to the back of the horn button. That is just to hold it in place while you push everything together. I hope this helps.
jason
77 f100
Old Dec 27, 2005 | 01:19 PM
FEFordFan's Avatar
FEFordFan
Thank you all for your help; I finally got it to work. There weren't indentations on the fiber horn disk, which is why I couldn't figure it out. However, all I had to do was just push hard and it snapped on. I feel like a fool - I can port & polish heads and rebuild engines, but I can't get a stupid steering wheel on! Thanks again for the help!
Old Dec 27, 2005 | 06:20 PM
User 71024's Avatar
User 71024
Don't feel bad, the one my son bought for his Stang was a pos , I ended up making 3 small "L" brackets and drilling 3 holes in the horn button and screwing them on with ss machine screws. Royal pain in the butt, but it stays on now.
Old Dec 28, 2005 | 09:38 AM
trinogt's Avatar
trinogt
That's the worst part about aftermarket steering wheels. The horn button. I bought one from the junkyard one time, and it was installed with no spring at all, and I had no idea that it even used a spring. So yet, I had nothing but trouble getting it to work. I ended up using a horn button mounted under the dash.
Mark
79FordBlake
37
Nov 11, 2013 08:35 PM
av8r210
1983 - 2012 Ranger & B-Series
13
Apr 18, 2011 09:56 PM
mclaughlin31
Feb 6, 2006 08:00 PM
tripndrag
21
Aug 28, 2003 07:41 PM
cjcathey2002
Jul 15, 2003 04:09 PM
