Moisture in Oil
Moisture in Oil
I checked my oil this morning and the entire dipstick was covered in rust and moisture. The oil on the stick looked like it had dirt or rust in it, alot of it too. I am going to change my oil soon as possible but should I be worried about this? I don't know if its just the tube or actually inside the motor. We have had really hot, humid weather the past few days and the last time I checked my oil it was not like this. Thanks
Change it right away. Rust in the oil is a very bad thing, but it doesn't normally show up in an engine that gets driven. You see it a lot in old motors that have been sitting for years and the crankcase is ventilated to outside air.
Yup, they were exactly the same length going into the block, just shorter coming out. I figured it would be easier changing it then fighting with steel wool or what not.
This is rather common with these newer engines. Moisture condenses in the dipstick tube. As long as there is no water in the oil when you change it, there's nothing to worry about. Sometimes the dipstick tube dries out with driving. Other times, on some vehicles, no matter how much it is driven, the moisture remains.
jayro88
21
Sep 1, 2013 08:45 AM
carlforman
Jul 11, 2012 05:16 PM
jwtaylor
Mar 19, 2002 07:18 AM
