fuel filter.....
Old Jul 7, 2005 | 06:46 AM
dieselhp's Avatar
dieselhp
Stay away from the filters with the cap!!! You are out on the road and need a filter you have to buy the one. Most stores stock the one without the cap. Also the ones with the cap cost more money.
Old Jul 7, 2005 | 08:07 AM
TaosCowboy's Avatar
TaosCowboy
Beware:
Be sure you get the filter seated all the way down in the can. I failed to do this last winter and discovered that diesel all over the engine compartment is difficult to clean up. I thought the cap was tightened down all the way, boy did I pay the price.
Old Jul 7, 2005 | 05:33 PM
BobbyDiesel71's Avatar
BobbyDiesel71
fuel filter installation
The cap and screen seemed permantely attached, but I will have to take it apart again and be sure.
Old Jul 7, 2005 | 06:57 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by slc10844
..... and drain into a clean plastic container. That way I can inspect what comes out, and if its clean put it back in the tank. ...
Doesn't the fuel filter separate the water from the fuel as well? Might not be a good idea to pour that back into your tank.
Old Jul 7, 2005 | 07:13 PM
Medic 66's Avatar
Medic 66
Check this out..............
https://www.ford-trucks.com/article/...ke_Diesel.html
Old Jul 7, 2005 | 07:25 PM
slc10844's Avatar
slc10844
If the fuel looks clean it goes in the tank. If not, it gets gets dumped in with the waste oil. Either way is better than draining it on the ground.
Old Jul 8, 2005 | 10:09 AM
Shake-N-Bake
Agreed. Draining on the ground is not good. I have a large plastic water bottle with the snap cap removed and a piece of fuel hose that slides up the drain tube, the other end fits tightly over the cap cover on the bottle so nothing leaks when I drain my fuel filter housing. I'm not sure what clean diesel looks like....so I alway end up pouring the fuel into the waste oil containers.
fabieber
18
Feb 9, 2015 08:44 AM
HiSPL
Testing.....
Aug 19, 2009 05:52 PM
jschira
Nov 30, 2002 08:04 PM
leonharu
15
Sep 15, 2002 07:15 PM
truckfarmer
Dec 23, 2001 09:18 PM
