fuel filter.....
Old Jul 6, 2005 | 10:35 AM
buckshot047's Avatar
buckshot047
fuel filter.....
any tips or things I need to watch for...also is it just as simple as unscrewing the cartridge and putting a new one in or do you need to purge air somehow? First time changing it myself...oh yeah 02 PSD...
Thanks
Old Jul 6, 2005 | 11:37 AM
Max1775's Avatar
Max1775
Pretty straight forward change. Make sure the engine is not running (just kidding). Unscrew the lid using an oil filter wrench. Remove the old filter and make sure you get the o-ring that was on the bottom of the filter. Sometimes it will stay in the housing. Place a container under the truck and drain the remaining fuel out of the housing. There is a yellow fuel drain lever on the side of the housing, you turn it to drain the fuel. Clean out the bottom of the housing if there is any crud in there. Install the new filter and lid gasket and tighten the lid. Close the drain valve. Cycle the ignition swith on for about 10 seconds without starting the truck (do this 4-5 times to prime the housing). Start the vehicl and check for leaks. Pat yourself on the back and drink a cold one (this last step is the most important). Good luck.
Max
Old Jul 6, 2005 | 11:43 AM
Barnacle Bill's Avatar
Barnacle Bill
Had to chuckle at step one. Nice touch.
You know some lawyer would zap you if you left it out.
Old Jul 6, 2005 | 12:05 PM
Max1775's Avatar
Max1775
Lol, ain't that the truth... Always an ambulance chaser lurking in the midst!
Old Jul 6, 2005 | 12:19 PM
dieselhp's Avatar
dieselhp
Check the screen on the side of the housing, make sure it is clean before you install the new filter.
Old Jul 6, 2005 | 05:30 PM
trike1946's Avatar
trike1946
Is any brand better than another. I'm also new to PSD. Thanks
Old Jul 6, 2005 | 05:39 PM
Max1775's Avatar
Max1775
I've been all my filters from Baldwin, But when I'm not stocked, I get them from Napa.
Max
Old Jul 6, 2005 | 05:47 PM
JOE-M's Avatar
JOE-M
If the new one comes with the cap already attached, DO NOT throw the factory one away. You may need it someday if you just use filter catridges. The cost about $10 or $12 to replace them.
Joe
Old Jul 6, 2005 | 07:48 PM
Ed 4X2X's Avatar
Ed 4X2X
Remeber to rub so diesel on them new O-Rings....
Old Jul 6, 2005 | 07:55 PM
trike1946's Avatar
trike1946
Is there some type of hose on the drain? Or does it just run out everywhere? Thank you.
Old Jul 6, 2005 | 08:07 PM
JOE-M's Avatar
JOE-M
It just runs and makes a mess everywhere. You can add a small hose and clamp to direct it where you want it.
Joe
Old Jul 6, 2005 | 09:38 PM
BobbyDiesel71's Avatar
BobbyDiesel71
Joe
I got a fuel filter from Napa, it was a two-piece unit with the screen in front of the filter, no cap, though
when I removed the cap from the truck, the screen seemed to be attached to the cap and I just saw the filter in the bottom of the filter assembly
what is up with that?
Old Jul 6, 2005 | 09:57 PM
FleetFilterBrian's Avatar
FleetFilterBrian
You can get the same filter from us as you'd get from Napa, if you're interested.
Old Jul 7, 2005 | 05:26 AM
JOE-M's Avatar
JOE-M
If I understand what you are saying, the filter just came apart. Shouldn't be a problem. It just pulled loose from the cap didn't it?
Joe
Old Jul 7, 2005 | 05:49 AM
slc10844's Avatar
slc10844
Its not very environmentally friendly to just let the fuel drain on the ground. I attach a hose on the drain line and drain into a clean plastic container. That way I can inspect what comes out, and if its clean put it back in the tank. I know its not much fuel, but at the price of diesel I don't want to waste any.
