Rpm Intake Plug
Old Jul 5, 2005 | 07:55 PM
bshackelford711's Avatar
bshackelford711
Rpm Intake Plug
as many of you know i have got the performer rpm intake for my 390. I have got it figured out (i think) I have got everything bolted up to it for the most part but i have a threaded hole on the top (i think it is for the ERG EGR which ever it is.) of the intake chanels for the 5th intake port.
What can i use to plug this hole?
I know the one closest to the thermostat is for the elbow for the heater hose but then the other one is the one i am questioning.
Thanks
-Brandon-
Old Jul 5, 2005 | 08:12 PM
seetwisted's Avatar
seetwisted
Thats about where the temp sending unit goes on my offenhauser intake...are you sure the hole is in the#5 intake runner? Or the water jacket?anyway...will a pipe thread plug work?
Old Jul 5, 2005 | 10:25 PM
bshackelford711
I made a quick look and then had to make a quick run to work (got to love those call outs) I will go back and check.
I did blow air into the top of the intake and could feel it coming out of the whole but i will go and double check
Old Jul 5, 2005 | 11:01 PM
hiball3985's Avatar
hiball3985
that may be a port provided for powerbrake vacuum...but I've never seen a performer intake..all my intakes are Ford
Old Jul 6, 2005 | 12:24 AM
gtex's Avatar
gtex
Yeah, that's the vaccum port, usually theres a tree that goes in there to provide vacuum to things like power brakes and the vacuum connection on an auto transmission. Just to the front (towards water pump) of that is the temp gauge port and to the left of that is the port for the heater hose. Looks in my gallery for a pic. you can see a brass fitting in the temp. gauge port.
Old Jul 6, 2005 | 12:31 AM
bshackelford711
well do i need to plug this or what?
My old stock intake did not have anything like that. OR at least i did not see anything but i may have missed it under all the grease.
I also took out my old elbow for my heater hose and that thing looks bad. Really rusted and the bottom of it is coming apart. I am going to replace it but where should i start to look for one?
I got the location for the temp sending unit. Just not the other whole.
Old Jul 6, 2005 | 12:35 AM
gtex's Avatar
gtex
If you don't have any vacuum accessories, I guess you could plug it. You sure don't want to run with it open. it's straight vacuum into the cylinder. You could suck up all kinds of dangerous stuff.
Old Jul 6, 2005 | 12:40 AM
bshackelford711
thats what i was thinking. Now would it be a bad idea to use like a non hardening silicone to put on thread to keep it from leaking or like permatex thread selant?
Old Jul 6, 2005 | 02:48 AM
gtex's Avatar
gtex
You probably don't need any sealer if you get a threaded plug that fits good. Otherwise, any of the basic sealers (black RTV etc) should work. Maybe even some teflon pipe tape. I can't belive your stock intake didn't have something. Do you still have it? Maybe it has a plug.
Old Jul 6, 2005 | 07:08 AM
bshackelford711
yeah i still have it. I will clean it up and look and see.
Old Jul 6, 2005 | 09:03 AM
bshackelford711
does anyone know what size and the threads per inch might be for the elbow that the heater hose conects to on the intake. The stock one that i have needs to be replaced bad.
Thanks
-Brandon-
Old Jul 6, 2005 | 09:19 AM
hiball3985's Avatar
hiball3985
take the old one to the autoparts store, you might not find an exact replacement but they should have something that works, it should be standard pipe thread
Hopsing69
Jul 12, 2013 01:49 AM
1951flatheaddave
Jan 20, 2012 10:25 PM
Annihilator
Mar 6, 2004 10:17 AM
MichaelJB
Jul 24, 2003 02:54 PM
karljay
Feb 24, 2003 06:09 PM
