Factory Flathead Aluminum vs Iron Intake
Hello all, just got a factory 2 bbl intake in the mail that is aluminum, I was told these were on canadian models. I picked it up on ebay for about $20 including shipping. The intake fits the 49-53 8BA flatheads.
My question is that when compared side to side the intakes look the same except for the number of bolt holes that hold the intake to the block. The aluminum intake has more holes drilled in it than the iron one does. If I can remember correctly I think the aluminum one has 3 more holes in it than the steel one, 2 on one side and 1 on the other side.
The iron intake has bosses where you could tell it could be drilled for an intake bolt but there is just no hole there.
I am not sure if the block is machined for the extra holes the aluminum intake has or not, I am thinking not.
My question is can I use the aluminum intake and just leave the extra bolt holes open? Nothing will fall into the block because under the holes in the intakle the block is solid.
Outlaw56
03-29-2014 06:36 PM
fifty-two_f1
Ford Truck Parts for Sale
05-02-2011 06:27 PM
lj98
03-05-2007 09:17 PM
